Gauge cluster indicator lights
For some odd reason, the following indicator lights DO NOT work:
- seat belt
- emergency brake
- low fuel
- THERE MAY BE OTHERS, I'M UNSURE...
Are all these connected in a way? I checked fuses and everything seemed fine. I can check again...
- seat belt
- emergency brake
- low fuel
if the car was used when you bought it, it is possible that the previous owner removed your bulbs. I hope your check engine light is working
[Modified by B_Cruz, 9:42 AM 9/11/2002]
From: Why so you can pretend like youre interested, FL/OK
Didn't you also switch your cluster over to GSR or ITR, do you think the switching of some of the wires may have shorted something?
Stevo2427
Oct 4, 2007 10:40 AM
