No start
Old Apr 27, 2010 | 02:32 PM
tommybonnet2008's Avatar
Default No start
Ok I know this has been asked a million timw=es but i cant seem to find the info anywhere. I did a mpfi swap in my 91 civic hb and after a week i got it running. Well I blew the motor so I got a new one. I hooked everything up and I have spark fuel compression but no start. My ecu throwec code 4 (ckp sensor) and 8 (tdc sensor) I have looked and looked and my wiring is right the only difference is im running a pr3 now. is that my problem or whats going on here im lost.
Old Apr 27, 2010 | 02:36 PM
BiG ChOr!Zo's Avatar
Default Re: No start
check your timing and try using another known working dizzy...not familiar with a pr3 but if it was me i would get a pm6...!!!
Old Apr 27, 2010 | 02:40 PM
pr3 is a obdo vtec for a jdm sir b16 and my dizzy is brand new!!! but I will check the timing again. thank you
Old Apr 27, 2010 | 02:48 PM
well you said mpfi so i was assuming you had a d-series non-vtec motor and just converted from dpfi to mpfi...!!!
Old Apr 27, 2010 | 02:52 PM
I do have a d seires vtec but the ecu is for a b16 but my buddy ran it in his crx so I thought it would work
Old Apr 28, 2010 | 02:17 PM
So I re did my timming twice now and still no start. I have spark I have fuel but nothing. only code 8 (tdc sensor) Do I need a new dizzy? whats going on here?
Old Apr 29, 2010 | 11:26 AM
So i have checked and triple checked iring spark fuel timming everything. I still dont start and get code 8 should I try a new dizzy? mine is brand new!! could my main relay be the problem it only works sometimes? Im so lost!!!!!!!!!!!!
Old Apr 29, 2010 | 01:09 PM
JCRXTURBO20916's Avatar
what kind if disributor do you have i though they only make obd1 for a sigle vtec. if it is a obd1 you cant use a obd0, specialy the pr3 thats for a dohc, it just wont run right. pr3 also has a knox sensor is that even hooked up on your motor.
Old Apr 29, 2010 | 01:55 PM
lunalink's Avatar
uuumm.
you cant use a DOHC ecu for a single cam. and as stated it has a knock sensor.(your motor doesn't have it)
you either need a pm6 (stated before) or pm8.(i have one $)
* what did you swap mpfi? single cam? DOHC?
Old Apr 29, 2010 | 01:56 PM
lunalink's Avatar
Old Apr 29, 2010 | 03:16 PM
well on the last motor I used a pg7 out of a integra ran grat lots of power. And i have a obd1 dizzy. I also know that the pr3 ecu will work because i put it into my buddys crx and it ran like a champ. I have a d15 with a d16z6 head. But ill try the eu first. what obdo ecu should I run?
Old May 1, 2010 | 11:28 PM
ok changed the ecu to a pm6 nothing took my valve cover off and found a bent valve replaced the head had my motor timmed by a mechanic and still no start. whats going on?????????????? still throwing tdc going to try a known working dizzy tomorrow.
Old May 3, 2010 | 02:02 PM
SO I figuerd out im not getting injector pulse?????? Re did wiring all soildered still nothing! what do I check next????
Old May 3, 2010 | 10:38 PM
so I figured it out!!! I have a obdo ecu and a obd1 dizzy Thanx to those who tryed to help
Old May 3, 2010 | 10:52 PM
this is sig material but i just cant get rid of the right wing nutjobs sig im currently using
Old May 3, 2010 | 11:10 PM
ryanevansoh's Avatar
hahaha dumb mistakes happen
Old May 4, 2010 | 06:02 AM
so does any one have a obdo si dizzy for $
Old May 4, 2010 | 03:08 PM
i do
Old Aug 20, 2010 | 10:16 PM
ok i cant seem to remember how to use this site. I dont know how to post anymore. So im just going to write here. I just bought a 88 civic with a d16a6 dpfi bone stock. At low rpm it has no power bogs hel** bad. What causes this. I replaced Dizzy cap rotor plug wires oil change. Messed with my dizzy timing cause some one told me to. Nothing works??????????? Help me plz im lost. Thanx
Stacygifford
Jun 14, 2014 08:20 PM
lilhatch89
Feb 4, 2008 09:56 AM
turboluv
Jan 25, 2007 05:25 PM
Turbo88hatch
May 4, 2005 09:16 AM
bob06
Mar 24, 2005 06:55 PM
