BARO sensor?!?!?!?
Old Apr 26, 2010 | 03:50 PM
babiboidb1's Avatar
Default BARO sensor?!?!?!?
hey everyone so im having a code 13 being thrown up on my ecu. it says it the BARO sensor. i read was reading that sum cars its located in the ecu and sum its located externally from the ecu. i have a pm9 ecu and i cant seem to get a answer if its in the ecu or externally. im hoping sumone can help me out. anyone have a clue???? i cant drive my car because of this problem nd i need it resolved ASAP. hlp me please!!
Old Apr 26, 2010 | 04:35 PM
vtec_ef8's Avatar
Default Re: BARO sensor?!?!?!?
Im not 100% sure but I think its on the passenger side kick panel.
Old Apr 26, 2010 | 05:43 PM
babiboidb1's Avatar
is it a box type thing with a plug going into it.
BUMP BUMP
please help
Old Apr 26, 2010 | 07:36 PM
D16SiHatch's Avatar
sounds like you found it
Old Apr 26, 2010 | 08:49 PM
89LSED's Avatar
What do you have in the car?
the 91 Teggy has the baro inside the ECU.
I learned that when i had a full 91 harness in my 4 dr.
Old Apr 27, 2010 | 04:40 PM
babiboidb1's Avatar
ok i ended up replacing the BARO sensor but it still throwing up the code for it. It has to be the wiring? i put the baro in and another map sensor in reset the system and the car was relining i guess until it read the ecu and went back to the way it was. is there a wiring diagram out the for it. maybe a wire got cut...please help me. does it run straight to the ecu?? maybe i can run a tab straight there!?!
bmoua
Apr 15, 2007 12:24 AM
hybrid1990crx
Apr 6, 2006 03:05 AM
JODYG35950
Dec 15, 2005 06:14 AM
satan_srv
Dec 4, 2002 03:56 PM
.brad
Jan 21, 2002 02:01 PM
