pics inside ,need your opinions
i had a valve snap on me. i have been trying to figure what went wrong.
The valves has about 1200 miles on it they were ferrera flat tops and were new as was the spring retainers and keepers. the retainer and springs were still in place as shown in the picture.
let me know what you guys think happened in your opinion. im kinda lost with trying to figure the cause
the motor was not making any unusual noises
were you using a stock spring with the brian crower retainer? you need to check your installed height with your setup so you can see if you have enough spring pressure. the valve possibly was out of control there for causing it to break.
Need more info on your set up.
