Honda Cx Wiring Question
Old Apr 26, 2010 | 01:45 PM
venomscx's Avatar
Icon3 Honda Cx Wiring Question
I had a 95 honda civic given to me that had a small elec. fire burned the fuse box the dash and pass side air bag also the battery. I have a friend who owns a junkyard he was able to pick me up a 92 civic dx. (both cars are hatchbacks) My question is this I have a complete wiring harness from the 92 due to the fire alot of the harness in the 95 was destroyed can i basically hack out the section that was damaged and solder back in the harness from my 92 parts car.
Old Apr 26, 2010 | 04:21 PM
CivicSpoon's Avatar
Default Re: Honda Cx Wiring Question
The '92 harness won't have the wiring for the passenger side air bag, because it didn't have one. But everything else will work.
Old Apr 26, 2010 | 05:39 PM
venomscx's Avatar
Not exactly the question i was asking let me rephrase basically i need to repair the fuse box (which i have a newish one.) The wiring from under the fuse box that runs through the firewall can i cut out 1.5 feet of it and splice in the same area of harness from my parts car? Basically color codedly speaking are they the same? If i remember correctly the srs systems although being different between the two cars still use a separate harness all together?
Old Apr 26, 2010 | 05:51 PM
94EG8's Avatar
Seagull Management
IIRC '92 wire colors differ somewhat from other years. Its a lot less work to just replace the entire harness really.
Old Apr 26, 2010 | 06:06 PM
burnykawizzle's Avatar
yeah i had that problem and i dont know what model my hatchback is so i just got the wiring harness from a 92 honda civic dx and everything was plug and play... i change the harness from the fusebox to the headlights and it was only 100
a9110108
Honda Ruckus and Scooters
Nov 6, 2008 12:46 PM
KrispyKreme
Jul 31, 2005 06:29 PM
CiViC dRaGsTaR
Apr 27, 2001 08:22 AM
