RARE 2000 honda civic si
2000 honda civic si ebp 15,501 original miles always garaged, only driven in nice weather bought brand new. I had earl laskey from laskey racing build the short block balanced and blueprinted to handle up to 700hp, and tom from portflow build the head. all of the aftermarket parts are brand new. basically bought new in july 2000 and tore it apart in april of 2002 and has been sitting there ever since and has been garaged engine needs assembled. i have all of the factory parts as well and reciepts for all of the aftermarket parts, willing to deliver with in 250 miles. need to sell asap might be willing to sell parts seperate.
MAKE OFFER
ENGINE
oem honda rebuild kit
portflow port and polish,valve job,polish chambers, open chambers to 84mm,supertech valves spring and retainer kit
benson sleeved 84mm
pauter rods
cp pistons
str bronze fuel rail
str 70mm throttle body
AIR carbon fiber intake manifold
arp head studs
hasport motor mounts
cometic head gasket
msd digital 6 plus
msd ignition coil
magnecor wires
quafie lsd
samco radiator hose kit
spoon oil filler cap,radiator cap, drain plug set
tilton clutch twin disc w/ modified stock flywheel
tilton hydrualic release bearing,tilton 75 series m/c kit,tilton m/c adapter
thermal 3" exhaust
INTERIOR
civic type r carbon fiber bezel
jdm shift boot cover
apexi rev speed meter
white dash gauge layover
SUSPENSION
koni fully adj coilovers
full race traction bars
spoon rear lower tie bar
spoon front lower tie bar
EXTERIOR
oem fog lights
rear spoiler
blue tinted windows
racing harts cpo35 17" white w toyo proxes
c-west eye lids painted
MAKE OFFER
ENGINE
benson sleeved 84mm
pauter rods
cp pistons
arp head studs
cometic head gasket
msd digital 6 plus
msd ignition coil
magnecor wires
quafie lsd
thermal 3" exhaust
INTERIOR
SUSPENSION
EXTERIOR
oem fog lights
rear spoiler
blue tinted windows
the title will say the miles or you can use the vin to look at any history about the car so when ever it went in for anything it should come up and what the miles where at that time
Have the title I'm the original owner bought with 15 miles drove it one year and has been in a garage for the last 8 years torn apart has not been licensed since 2002 so there has been no activity with vin #
