4th gen Front lower balljoint same as Rear lower?
Old Apr 26, 2010 | 01:32 PM
SteveoBA8's Avatar
Default 4th gen Front lower balljoint same as Rear lower?
I've been searching and some older threads mentioned that the Lower Front BallJoint on 4th gens is the same for the Rear Lower, is this true? I can't find any rear lower ball joints but i've found front lower ball joints. Doing a suspension overhaul , Thanks guys! Pirate, Mgags one of you OG's has to know if they are the same.
Old Apr 27, 2010 | 05:15 AM
SteveoBA8's Avatar
Default Re: 4th gen Front lower balljoint same as Rear lower?
Anyone replaced their rear lower ball joint? I'd rather not buy the complete knuckle from honda and get r@ped.
Old Apr 27, 2010 | 01:16 PM
pprowler6's Avatar
99% sure they are the same. I have 4 new honda balljoints that are ready to go in so ill be able to tell if they fit when i press them in.
Old Apr 27, 2010 | 02:52 PM
SteveoBA8's Avatar
That would be much appreciated. Thanks man.
Old Apr 27, 2010 | 05:44 PM
ralpheezy's Avatar
try checking the part numbers on majestic honda.
Old Apr 28, 2010 | 08:34 AM
SteveoBA8's Avatar
Majestic Honda only sells the rear Knuckle assembly =$300+. No parts suppliers sell the rear lower ball joint by itself for a 92-96 prelude. That's why I asked if the front lower's were the same Ralphezzy.
Old Apr 28, 2010 | 11:09 AM
pprowler6's Avatar
fyi prelude balljoints were recalled from 96-99 or something like that so u can get the balljoint kit from honda. thats what i did.
part number is 04510-sl5-000. it comes with 2 balljoints and is like 35 or so dollars. I bought 2 kits so i can see if the rears will fit.
Old Apr 28, 2010 | 12:12 PM
E-Money's Avatar
iirc legend balljoints fit the rear.
Old Apr 28, 2010 | 12:14 PM
SteveoBA8's Avatar
Oh, thanks pprowler I never knew there was a recall. Let me know if those suckers fit the rear.
Old Apr 30, 2010 | 03:04 PM
SteveoBA8's Avatar
I just removed my rear lower balljoints. Put the knuckle upsidedown in a vise. I used a 27mm deep socket and a BFH, some good hits and they came out very easily. I'm going to take one to the parts store when I have time and mic check them with the front lower balljoints and confirm. Any recommendations on lower ball joint?
The local NAPA has DANA( with new c-clip/sealed) for $66.99(1)
And Orielly's has MOOG sealed for $33(1)
Thanks for any advice.
Old May 3, 2010 | 05:15 PM
SteveoBA8's Avatar
Just installed front Moog lower ball joints into my rear knuckle. They are the same.
pprowler6
Mar 10, 2012 11:14 AM
brotherparker
Mar 5, 2009 05:13 PM
brotherparker
Feb 21, 2009 08:42 AM
pprowler6
Mar 4, 2008 03:51 PM
wstef
Mar 7, 2004 11:58 PM
