For Sale: Integra Front Subframe, lower control arms, and sway bar
I have a subframe with tie bar and sway bar off of a 2000 Integra GSR. The sway bar is 24mm. I've done a little research and provided links below for info on swapping sway bars, contol arms, and subframes onto civics. I've also read that cars that didn't come with a sway bar can just swap the entire subframe assembly with control arms to add one. I looked for that link but couldn't find it. These links do however tell compatability of parts between Integras and Civics. I'd like to get $50 for the sway bar with the end-links and brackets but the endlinks look like they need new bushings. The subframe is $25 and the control arms are sold.
And this subframe is for power steering rack and pinion which I've read makes a difference if you don't have power steering.
http://www.jdmuniverse.com/forums/view_ekswaybars.html
http://www.d-series.org/forums/898602-post1.html
