APEX'i WS catback rubbing rear sway!!??
Old Sep 10, 2002 | 10:48 PM
kappa's Avatar
Default APEX'i WS catback rubbing rear sway!!??
Recently I've encountered a problem w/ my after market exhaust piping and my aftermarket rear sway. I have the Apex'i World Sport catback exhaust system and a Skunk2 rear sway bar (21mm). I do not know the exact diameter of the width for the exhaust piping. My piping seems to be rubbing against the sway on the right rear side of the car ... right to the left of the rear right wheel. The piping seems to not clear the sway ... resulting in a nasty metal on metal sound whenever I make a left turn. What are some things i can do to fix this??? I do not want to spend a lot of money on fixing this ... any simple remedies? I've though of adjusting the hangers to pull the exhaust up higher ... yet its already pulled quite high. Also ive came up with the idea of wrapping some high resistance header wrap over the piping so it wouldn't be as loud when it rubs. Any suggestions or knowledge of this subject???
Thanks.
-ryan
Old Sep 10, 2002 | 11:12 PM
dnt94civic's Avatar
Default Re: APEX'i WS catback rubbing rear sway!!?? (autonomous R)
Is your car lowered w/ adjustable coilovers? if so, raise the car higher. That is what I had to do to mine.
Old Sep 11, 2002 | 09:08 AM
TKBLAZER's Avatar
Default Re: APEX'i WS catback rubbing rear sway!!?? (dnt94civic)
take it to a muffler shop and have them cut the hangers and raise the exhaust a bit...or if you can find a shorter rubber hanger that would work
Old Sep 11, 2002 | 10:26 AM
ALF's Avatar
ALF
Not to insult your intelligence, but maybe the swaybar is upside down?
If you even mount the stock one upside down, it will rub.
Old Sep 11, 2002 | 12:38 PM
aznmc16's Avatar
Default Re: APEX'i WS catback rubbing rear sway!!?? (ALF)
i raised my apex'i ws by redoing the hangers. the apex exhaust gernally hangs really low.
Old Sep 11, 2002 | 12:50 PM
TKBLAZER's Avatar
Default Re: APEX'i WS catback rubbing rear sway!!?? (aznmc16)
there is your answer
Old Sep 11, 2002 | 04:47 PM
Isaac's Avatar
New User
Default Re: APEX'i WS catback rubbing rear sway!!?? (TKBLAZER)
I had a Apex Dunk (mother of exhausts) on my car with a ITR swaybar and there were no problems. You're rear swaybar is probably upside down.
Old Sep 11, 2002 | 07:29 PM
ALF's Avatar
ALF
Default Re: APEX'i WS catback rubbing rear sway!!?? (Waxing "The Carrot")
Yup, I have a WS also with an ITR swaybar (which is a WHOLE 1mm thicker! ) and I have no rubbing problems whatsoever. Only if the swaybar were mounted upside-down would the swaybar begin to rub the piping. Usually you only start running into problems when using 3" diameter piping.
Also, the whole WS hanging lower than normal doesn't seem to apply to me.
[Modified by ALF, 11:30 PM 9/11/2002]
Old Sep 12, 2002 | 09:53 AM
RockDawg_GSR's Avatar
yea prolly upside down.U can get some like rubber inserts and stick em between the 2. I used that for my aem, it rubs i think a AC line or something i cant remeber.But yea the rubber thing helped.
Old Sep 12, 2002 | 09:56 AM
IntegraGSR23's Avatar
When you say "redoing the hangers", are you refering to the rubber thingies or the actual hanger bracket?
yee SERIOUS
Suspension & Brakes
Jun 30, 2006 04:11 PM
E-lude78
Aug 31, 2003 05:57 PM
kappa
Nov 5, 2002 07:58 PM
kappa
Sep 11, 2002 03:34 AM
