f22b2 valve cover problem
Old Apr 25, 2010 | 05:10 PM
czsmola's Avatar
Default f22b2 valve cover problem
Hi first time poster..
I had been changing my valve cover gasket, I had everything back together and i guess i put to much power behind it it but i broke the bolt on the front right that hold the valve cover down.. it is a long bolt not sure what it screws into but i would assume i need to use a torque wrench... how much torque should be used? alos dose anyone know if this bolt is the same from other honda motors...
Old Apr 25, 2010 | 05:34 PM
davey5300's Avatar
Default Re: f22b2 valve cover problem
torque is 7.2 lbs. Them bolts break very easy so got be careful with them.
Old Apr 25, 2010 | 05:38 PM
czsmola's Avatar
is that just for the valve cover or putting the new stud in? also is there something else i need to worry about?
JJT211
20
Apr 19, 2013 02:14 PM
cryingsuns
Apr 16, 2012 09:58 PM
Nino_eg6
10
Oct 20, 2011 05:39 PM
bartek_b
Apr 15, 2003 11:21 AM
