solid epoxy in motor mounts?
Old Apr 25, 2010 | 03:59 PM
Sordz's Avatar
Default solid epoxy in motor mounts?
window weld isnt cutting it anymore so I was curious to see if this would work to fill my stock motor mounts- think this will work?? Its not a daily driver but I do drive on the street and cant do the rear mount only the tranny and side(front is solid already).
here is the full link, thanks for any input
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Old Apr 25, 2010 | 04:05 PM
E-Rok's Avatar
EPIC TUNING
Default Re: solid epoxy in motor mounts?
most people use a sort of polyurethane like window weld or something of that nature
Old Apr 25, 2010 | 06:52 PM
perseverance's Avatar
i use polyurethane, they sell it at home depot for like 5 bucks a stick. i've been running my mounts for about a year now and i have no issues with them. the key is to let them cure for a week before installing them. my buddy installed his within like 2 days and it's a no go after a couple months. i did all of my mounts minus the driver side mount because i have an ek and well it's just not possible. good luck.
Old Apr 25, 2010 | 07:46 PM
Jaker's Avatar
I used this stuff for my motor mounts. It's pretty stiff, but there's a couple different hardnesses you can buy, and you can vary the amount you put in the mounts to alter the stiffness/rigidity.
http://www.devcon.com/products/produ...%2094%20Liquid
Old Apr 26, 2010 | 05:17 AM
sicones's Avatar
wow. you are cheap. you should have no problem finding someone on here selling their used avid or hasport mounts. btw that exopy will crack and fall out
Old Apr 26, 2010 | 05:44 AM
pradaman's Avatar
a ek mount is possible i have the stock ek mount redone in aircraft material
its the same material used in airplanes landing gear
Old Apr 26, 2010 | 09:17 AM
Sordz's Avatar
its a 93 accord race car and those mounts will not work, thanks for your input on the cracking though i will have to find something else.
Old Apr 26, 2010 | 12:33 PM
welfarepc's Avatar
steel + welder = solid mounts
Old May 6, 2010 | 07:50 AM
FIST321's Avatar
x2 u wont ever have to worry about it wearing out either
Old May 7, 2010 | 08:44 AM
mikesrex's Avatar
yep, it works every time for me!
Old May 7, 2010 | 01:51 PM
AdReNaLiN's Avatar
Do you solid mount the entire engine? All 4 mounts?
smokey.23
22
Mar 24, 2009 09:01 PM
Kaspk
17
Jan 19, 2008 06:54 PM
Rod.
Dec 31, 2005 07:05 AM
W O T
Oct 17, 2005 05:23 AM
6GACCORDH22
Sep 11, 2002 06:01 AM
