ef sedan frame and tranny question
91ex wth y8 head si tranny, makes a hissing noise, not really grinding,while in gear. Previous owner said push bearing? Im lost...
88 lx sedan, headlight housing bent up, could it be replaced? Or is it welded, i didnt c any welds...
EDIT: dont give me crap about the terminology, i THINK the previous owner said "push bearing", but i could be wrong.
Push bearing? There is a pilot bearing and a throw out bearing. Then there is also an input shaft bearing that could make that sound. When you say it makes that sound in gear do you mean while driving or when you push in the clutch?
The noise is MOSTLY heard while letting off the clutch, during shifting.
also, this is the piece i need, number 1. is this welded anywhere?
if the motion of th the clutch is making a differience then i dont think it would be main shaft.
Im thinking throwout bearing. or "push" bearing like you perviously stated.
I believe that the headlight housing is spot welded on.
Once i fix the LX's headlight housing/hood/fender, i'll be using that as my daily.
I dont know if the housing could be "bent back", i'll have to check it out this weekend.
more than likely your input shaft bearing is going bad. find another tranny
Because that scraping noise masks the noise of the tranny. So its hard for me to tell what exactly is happening.
Manolo
Aug 27, 2007 03:14 PM
EK k kay
Apr 8, 2005 08:06 PM
NipponRacing
13
Sep 5, 2003 06:42 AM
NipponRacing
May 3, 2003 03:09 AM
