Temperature keeps going up and down...very weird
Old Apr 25, 2010 | 01:08 PM
danielblushtein's Avatar
Default Temperature keeps going up and down...very weird
Hey I got a 95 gsr in a 95 eg. I was doing some motor work and took off the head. Then I filled the radiator with coolant and let it idle with lid open to get the air out. But I am not totally sure if I got all the air out.
The car temp used to always be a little less then middle. Lately I have realized that the temperature starts to go up(like 1/5 away from red mark) when I am driving. I turn on the heater and it goes down to normal. Sometimes in traffic it will do the same thing. My radiator fan works good. Usually the temp goes up and then down to normal. Seams like the thermostat opens and the temp goes down. Something like that.
Maybe start with thermostat?
Old Apr 25, 2010 | 05:19 PM
zdub907's Avatar
Default Re: Temperature keeps going up and down...very weird
its gotta be an air pocket just open the lid turn the car on and give it gas from under the hood and fill as needed
Old Apr 25, 2010 | 06:03 PM
vtaker's Avatar
There's a bleeder valve right by the top radiator hose on most B series.
Old Apr 25, 2010 | 08:42 PM
last time I did that the coolant just rose and went over
hhhmmm... I think I still have the civic radiator
Old Apr 25, 2010 | 09:41 PM
HondaManMike's Avatar
jack up the front of the car as much as possibleand purge the system, make sure your heater is on hot and fill away. be patient as this can be time consuming., gsr's for some reason always retain a fat air pocket just be patient
Old Apr 25, 2010 | 10:16 PM
are you sure it wont start to overfill?
other than that thanks for your advice
Old Apr 25, 2010 | 10:35 PM
cypressink's Avatar
depending on the year of the car you should have a bleeder valve. when the car is really hot, and the heater is on full blast with the vent set on recycle. drive the car down the freeway and get it REALLY hot and warmed up. stop at a gas station turn off the car and crack the bleeder valve open real quick and close it. it should spew a solid coolant out instead of bubbling. it shouldn't be opened for more than a 1 second. if it bubbles the first time, repeat(you don't need to drive it again if it is still hot). the bleeder valve can be found by following the top of the radiator hose to the block. it should pretty obivous. if you don't have it, get it really really hot and make sure you have coolant in the resevoir. it should bleed it self out over time just make sure you have coolant.
i bled my integra everyday for a like a weekend. letting it idle hot doesn't get it hot enough to get that bubble out.
Old Apr 25, 2010 | 10:43 PM
vtaker's Avatar
whoops i didn't say it right...
i mean there's a bleeder valve on the head right where the top rad hose connects to the head.
Old Apr 25, 2010 | 10:48 PM
RICKSAUTOMOTIVE's Avatar
my dads 1981 honda cvcc had a bleeder valve so i'm sure his does too. i know on the 81 its there because as a kid i tried to fill it with my grandpas greese gun thinkin it was a greese port like the big diesel trucks had. well obviously i had problems so i was able to get that thing off and after a little water came out i filled it with greese! LOL obviously i had bigger problems when my pops seen me messin with his car LOL got my *** beat!! damn i was like 8 or 9 then--no i was 11. damn i was a terrible kid LOL
yeahkkyle
Jan 27, 2013 11:30 AM
jlude90
Jul 13, 2008 04:46 PM
tpatt
May 1, 2007 03:57 PM
black_cap
Jan 3, 2007 01:07 PM
decible01
Mar 3, 2005 04:41 PM
