did b16a2 swap have some questions
Old Apr 24, 2010 | 07:06 PM
mtownsi's Avatar
Default did b16a2 swap have some questions
hey hows it going. i just swapped a b16a2 intomy 93civic lx.first questionis the rear trans bracket wich 1 ami suppose to use? second question is i have 2 codes #5 and #7 for the map and tps wereis themapsensor locatedon the d15b7 soi can swap it onto the b16? and i cracked the tps sensorcani use the stockone from the d15or do i need to replace it ? other than that the swap was easy thanksfor everyones help. o and any ideas of how to make the stockthrottlecable work?
Old Apr 24, 2010 | 07:12 PM
JDMh22eg9's Avatar
Default Re: did b16a2 swap have some questions
94-01 integra rear mount ( under 15 from your local junk yard) delsol vtec throttle cable even tho stock should work d15 tps will work im running a 90 dx civic one on my h22 haha bring out the grinder tho to get your old one off
Old Apr 24, 2010 | 08:22 PM
mtownsi's Avatar
ok thanks ill get that mount. i
and ill swap the t.p.s sensors
Old Apr 26, 2010 | 05:36 PM
mtownsi's Avatar
i have 1 more question wat p.spump and bracket do i use for this swap. the stock p.s line would not go into the b16a2 pump
Old Apr 27, 2010 | 08:35 AM
mtownsi's Avatar
bump bumnp any1?
Old Apr 28, 2010 | 11:49 AM
buff1110's Avatar
b16 pump and bracket with stock d-series line works, i would use a bracket for your throttle cable, something like this but for your year http://cgi.ebay.com/ebaymotors/88-89...item3a5a1a8177
revikan
Sep 2, 2010 04:27 PM
97_coupe
Sep 2, 2008 08:56 AM
Azxster
Mar 27, 2008 06:57 AM
civiceg500
Jun 26, 2004 10:36 PM
Kamin
Jan 7, 2002 05:02 PM
