bent rod?
ok Im in the process of rebuilding my motor and the reason Im rebuilding the motor in the first place is caused by a dropped valve, now my question after a dropped valve how often does a rod get bented? From the looks of it, its fine, eagle rods btw, I just want to reuse what I have to save some cash, is there a way to check?
yea you can compression test and see if the cylinder that the valve dropped in turns out lower than the rest, or you could take out all the spark plugs and sitck a long screw driver into the cylinder and slowly turn the crank and check the tdc height of each cylinder to see if they are all the same.
shouldn't. they'll probably just measure them... that's what i would do. just measure a good rod from the inside of the wrist pin hole to the inside of the crank journal with a dialed caliper then compare the measured results with the rod from the damaged cylinder. however you should deff. take it to a machine shop if you are unsure of your self.
hondapwr
Aug 28, 2005 09:36 PM
Its me DUB
Apr 2, 2005 11:59 PM
