450hp 15lbs pump gas dyno video.
Old Apr 23, 2010 | 03:28 PM
mrbh22's Avatar
Default 450hp 15lbs pump gas dyno video.
heres what i did today! i had the intake manifold give up on the bracket that holds the fuel rail to the injectors. but after a couple hours and some custom fab work we got back at it and made some power. i will give more info on the setup later.. 84mm gsr precision 6265...etc
read the middle graph the one on top is the previous run
http://www.youtube.com/watch?v=yXZy1D492sI
Old Apr 23, 2010 | 03:42 PM
base-op.1320's Avatar
Default Re: 450hp 15lbs pump gas dyno video.
Nice car and good numbers
Old Apr 23, 2010 | 04:53 PM
fukenricen's Avatar
very nice best of luck at the track
Old Apr 23, 2010 | 06:34 PM
mrbh22's Avatar
thank you sir!
same to you man! im hoping for 11.50 or better and 125mph or better.
Old Apr 23, 2010 | 08:58 PM
DeLucia's Avatar
Originally Posted by mrbh22
thank you sir!
It will do better then that. In my full weight EM1 at 430whp i went 11.2 @ 128
Old Apr 23, 2010 | 09:41 PM
mrbh22's Avatar
that sounds like a fun ride! i have no idea what this car weighs. and if i ran a 10.99 on pump gas i would be the happiest kid on the planet!
ps the tracks around here are junk... no vht no love for fwd cars. but i am planning on hitting indy sometime later on this year and i love that track!
Old Apr 23, 2010 | 09:50 PM
ROMEO856's Avatar
nice...i have a eg6 gutted (im 300lb) and i did 11.504 @121mph on 12psi in honda day last week
Old Apr 23, 2010 | 10:32 PM
30psi_gst's Avatar
thank you sir!
450whp should be good enough to run 10s with a little seat time. Ive seen stock motor GSR's making less then 350whp go 11.30-11.40s in full weight 99-00 Si Coupes.
Old Apr 24, 2010 | 07:24 AM
mrbh22's Avatar
i havent been down the track since 2006 so i am sure i will need to make a few passes to get back into the driving portion of things... i would love to see 10s .... i dont know what i would do. ...although i know im going to do a race gas tune for the IFO in columbus ohio and i know i can get it then,
thanks !
Mike
Old Apr 26, 2010 | 02:42 PM
area522010's Avatar
good ish
Old Apr 26, 2010 | 08:24 PM
mrbh22's Avatar
thanks? i dont know if that means good S**T or if it means it was ok...ish....
lol
Old Apr 27, 2010 | 08:44 AM
Tuned1's Avatar
Thumbs up!
Old Apr 27, 2010 | 05:01 PM
mrbh22's Avatar
Originally Posted by Tuned1
Thumbs up!
tuned by this guy!!!!!!!^^^^^^
Old Apr 27, 2010 | 05:13 PM
bads2k's Avatar
National Trails is open this friday we are headed over. Come on up and make some passes they actually prep pretty decent up here and the weather looks like it's going to be nice also
Old Apr 27, 2010 | 05:20 PM
01DC4's Avatar
have you always had this car?
Old Apr 27, 2010 | 05:52 PM
mrbh22's Avatar
man i would love to but i have to work.
no i recently purchased it in florida.
Old Apr 27, 2010 | 06:05 PM
bads2k's Avatar
nightshift? starts at 5pm. there is also one May 7th Friday night
Old Apr 27, 2010 | 08:01 PM
mrbh22's Avatar
i bartend. so yep nightshift. i might shoot for the may 7th. i gotta order me some 3.5in wide tires!
Old Apr 27, 2010 | 08:06 PM
01DC4's Avatar
I knew it looked familiar, You def picked up a nice car goodluck with it.
Old Apr 27, 2010 | 08:08 PM
mrbh22's Avatar
thanks man! i have had no problems with it.other than the intake mani braking on me on the dyno. but other than that i just put a full exhaust on it and tuned it. now to take it to the track and see what it does.
Old Apr 27, 2010 | 08:19 PM
01DC4's Avatar
Gato intake?
Old Apr 27, 2010 | 08:27 PM
mrbh22's Avatar
no its an old HP racing intake manifold. and the plate that you bolt the fuel rail to broke while we were on the dyno. so i got a guy to make me some support braces on the bottom and top and weld them in for me ... he did it all rite then and there. and to be honest that manifold is made with some seriously thick aluminum. it was every bit of 3/8'' thick. but it should never break again.
i will be making a new thread soon with racegas hp numbers and hopefully some timeslips in the 10's
Old Apr 27, 2010 | 08:33 PM
bads2k's Avatar
give me a call if you are wanting to head up to the track on the 7th we will head up also to help out.
Old Apr 27, 2010 | 08:40 PM
01DC4's Avatar
Found that in my photobucket haha Goodluck!
Old Apr 27, 2010 | 08:45 PM
mrbh22's Avatar
sounds like a plan. i will call you if i do decide to come up... are you taking your car?
thats awesome!
thanks for sharing that with me
