axle question on a swap
"These are 32mm axles. They will fit all Type-Rs EXCEPT a true JDM or international market Integra Type-R (the ones with 5 lugs). Those cars come with 36mm axles. USDM Type-Rs all had 32mm axles."
ok my engine is a jdm my car is a usdm 4 lug will they fit?
do they fit up to the engine or the transmission... is the trans. from a JDM type-R?
if so, and assuming both inner and outer joints are larger on the JDM model, you would need to have custom axles put together. i would guess no more complicated that swapping the larger inner joint onto a USDM axle assembly.
no ive put this engine in my last civic and i used the stock b16 axles, worked fine. i should have been asking if 32 mm is to big for my hub
What kind of civic? sorry your posts are kind of confusing me.
You put the engine in your last civic and used b16 axles which someone correct me if im wrong are 32mm. With 32mm axles you should have no problem puting them in, expecialy if you used them in your last civic.
Is your tranny jdm also or usdm?
