Post up Your Brake Setups
Looking to see what people are running for brakes.
I know most people are running stock, but im curious to see what others are running if they arent running stockers.
1.Booster/or boosterless
2. Master Cylinder size
3. Calipers/pads/rotors
4. Brake Lines/Brake Fluid
5. Strengths/weaknesses of custom brake setups compared to stock.
6. What size spacer for wheels and wheel size
My Current Setup
1. ITR booster
2. 1" ITR
3. Oem/oem front,hawk rear/ Oem
4. Earls Stainless Brake lines/Oem Honda
5. Quality fit and great from the factory
6. 5mm spacer weld magnum 13x9(forgot backspacing)
My Current Setup
1. ITR booster
2. 1" ITR
1. GSR Booster
2. GSR Master
3. Power Slots, Hawk HP+
4. OEM Honda
5. One of the best stopping cars I have ever owned.
6. 13x8 Volk TE37s, no spacers
2. GSR Master
4. OEM Honda
Drag Car
1. No Booster
2. Wilwood 1"
3. EG EX Calipers/Duralast C-max Pads/Brembo Blank Rotors/Stock Rear Drums
4. Stock Lines/Walmart Supertech Fluid
5. Great Pedal Feel and it stops 130+mph
6. No Spacers for now and on SI's with drag radials
DD
1. GSR Booster
2. GSR Master Cylinder
3. Acura Legend 2 Piston Calipers/Duralast C-max Pads/Brembo Blank Rotors F/R
4. Russel Steel Braided Brake Lines/Walmart Supertech Fluid
5. Stops better than any car I have ever drove
6. No spacers and 17" Rays Gramlights
1. No Booster
2. Wilwood 1"
DD
1. GSR Booster
Drag Car
1. No Booster
2. Wilwood 1"
3. Stock 5 lug type R brakes, Brembo rotors, forget the pads.....
4. ChaseBays brakelines (stainless single line in bay, to stainless teflon coated behind firewall)
5. Great Pedal Feel and it stops great 140+
6. No Spacers, Stock rears with neogens at 45psi and front Cragar Soft 8s 15x8 with 24.5/8.5 (had to grind the caliper bracket a slight bit)
1. No Booster
2. Wilwood 1"
Good Information so far, I expect that most people are running oem stuff since it is already super efficient from the factory. I always try to keep any and all parts on my car oem unless i need to upgrade for performance reasons. Cant beat, oem quality fit and finish!
drag:
NSX front calipers with rover mg zr rotors and duralast ceramic pads
RSX rear calipers with EP3 rotors with duralast pads
goodridge ss lines
ATE super blue fluid
ITR 1" booster and master cylinder
Em1 proportional valve
DD:
complete stock
goodridge ss lines
DD:
complete stock
si booster (stock for me and prop valve)
gsr front spindles, parts warehouse loaded calipers middle grade rotors.
all stock itr 5 lug rear (had a full 5 lug, no one wanted it. someone only wanted front. so im 4/5lug hahaa.)
and i dont even use all that. just throw out the laundry.
Does the CRX SI have the bigger hub size like integra and 96-00ek ex? Just curious if these will work with the bigger DSS hubs.
1.Wilwood Master Cylinder without a brake booster
2. 3/4" master
3. Front knuckles are DC2 with oem pads and rotors
4. Goodridge SS Brake Lines in all 4 corners, need to setup my lines to only go to the front brakes
5. Not as good as my full integra booster/master setup. =\ but I am able to stop without feeling unsafe. (120-122mph to last exit on the track, not really smashing on the brakes though).
6. No spacer but I do have a backspace on my Bogart Pro-4 wheels.
Tire is a 24.5x8x13...
2. 3/4" master
Romo Pyro
Suspension & Brakes
12
Feb 18, 2014 08:32 AM
