Removing injector wire cover
Old Apr 22, 2010 | 05:27 PM
brucepick's Avatar
Icon2 Removing injector wire cover
Gen 6 Civic -
How do I get the plastic cover cap off the injector wires, right behind the injectors?
I only found 1 clip, on the drivers side end. How do I get it off without wrecking it?
Thanks.
Old Apr 23, 2010 | 01:18 AM
brucepick's Avatar
Default Re: Removing injector wire cover
bumped
Old Apr 23, 2010 | 07:28 AM
thesmogman's Avatar
Originally Posted by brucepick
bumped
We need more info...
Are you talking about the black cover for the wires? There are four of those clips on the back side. Remove both 10mm bolts so you can twist it a bit might make it a little easier.
Or the actual injector plug's? pry back the wire on the side of the clip
Or the caps on the injector itself? Just pry off but I would not remove.
Old Apr 23, 2010 | 02:31 PM
brucepick's Avatar
I'm talking about the black(ish) cover for the wire set. About 2.5" x 8 or 10" long.
You mean remove two valve cover retaining bolts? I'm going from memory right now.
Thx.
Old Apr 23, 2010 | 02:57 PM
thesmogman's Avatar
Thx.
Sorry, I thought you were talking about a civic/crx.
Hold on and let me make a call........Sorry He's and 8th gen.
If it is like the one we are thinking about it is just pressed into the valve cover, Just pry it up
Old Apr 23, 2010 | 05:16 PM
brucepick's Avatar
Gen 6 with SOHC VTEC-E. It's an HX, 5-spd.
The plastic cover is between the valve cover and the manifold plenum thing.
http://i188.photobucket.com/albums/z...23_small_a.jpg
whp
Mar 11, 2007 12:53 PM
delguiner
May 11, 2004 01:09 PM
Gonzo_SiR
Nov 2, 2003 09:30 PM
Fred n J_v2.0
Mar 19, 2003 01:52 PM
PiYoImuT
Nov 4, 2001 12:10 PM
