JDM F22B O2 sensor help
Old Apr 22, 2010 | 05:10 PM
Mavlude's Avatar
Default JDM F22B O2 sensor help
I'm swapping a JDM F22B into my 92 s but the exhaust manifold that came on the F22 doesn't have a spot for an O2 sensor. Do the JDM motors not have O2 sensors? or do I need to use my old exhaust manifold and O2 sensor?
Also I'm using the jdm ecu if that helps
Old Apr 22, 2010 | 06:23 PM
Mervin's Avatar
Default Re: JDM F22B O2 sensor help
The F22 sohc has the O2 sensor @ the manifold right?
The F22B has it just before the collector (behind the oil pan)
Old Apr 22, 2010 | 06:44 PM
Mavlude's Avatar
Yeah the sohc one is on the header underneath the heat shield
Would it be fine to run it on the manifold?
Old Apr 23, 2010 | 11:34 AM
Mervin's Avatar
From your posts I gather u didnt get the F22B downpipe, only the header?
The H23 header/manifold will fit the F22B and if it were me, Id extend the wires and run O2 in the stock locations for the F22B (same location for H23/H22)
Old Apr 23, 2010 | 01:12 PM
Mavlude's Avatar
Yeah it didn't come with the downpipe but I do have my old one from the si laying around somewhere in the garage so I'll just use that. Thanks for the help
Old Apr 23, 2010 | 01:48 PM
Mervin's Avatar
NP & GL!
Import car center
Mar 19, 2004 02:04 PM
stripes777
Jun 27, 2003 07:46 AM
slipslap
Jan 18, 2003 06:56 PM
Ri5e
Mar 27, 2002 08:09 PM
