eg b16 fuel rail?
wats up im swapping a b16a2 into a 93 lx. im gunna use the stock d15b7 injectors since they are the same 240cc as the b16a2 but wat fuel rail do i use ? is there a difference between a d15b7 and a b16a2 fuel rail?
thanks
thanks
yes it did i wasnt sure if the line from the b16 would bolt onto the fuel filteron my eg since it looks different. and i was unsure of how to go about shaving the b16 injectors so the eg harness would fit. and how much to shave off
the d15 injectors will fit onto the b16 fuel rail with no problem. just unclip the injector harness' and pull firmly down, slide the new injector in and re-clip the injector. make sure you have all your rubber grommets on the IM before you try to start the car.
naptownrex
Feb 1, 2005 08:21 AM
b16delsol
Feb 3, 2004 07:40 PM
