Will 16 X 7.5 rims fit a '97 Civic coupe?
Old Apr 22, 2010 | 04:31 PM
secretsuperman's Avatar
Default Will 16 X 7.5 rims fit a '97 Civic coupe?
I was given a pair of 16" X 8" Niche chrome rims off of a '90 Integra. I would like to put them on my '97 Civic coupe. Will these fit? If so, what tires size should I use? I know little about this subject and would greatly appreciate any advise offered.
Thank you.
Old Apr 22, 2010 | 05:10 PM
Default Re: Will 16 X 8 rims fit a '97 Civic coupe?
So Sorry, CORRECTION - Bead to bead they're 7.5"
Old Apr 22, 2010 | 06:26 PM
r.wright's Avatar
215/45-16 or 205/45-16. depending on how low your car is and the offset of the wheels you may need to roll the fenders and/or use a camber correction kit.
Old Apr 22, 2010 | 06:42 PM
Thank you, the car is stock height. I'd like to use 205/50's. Can I?
Old Apr 22, 2010 | 06:55 PM
r.wright's Avatar
Default Re: Will 16 X 7.5 rims fit a '97 Civic coupe?
yes, 205/50 is okay for that width but using that size on your car will affect your speedo by about 3% and depending on offset, the tires may stick out from the fenders slightly.
i know you want to use a profile that will fill up your wheel well slightly.. am i correct?
Old Apr 23, 2010 | 05:46 AM
nsxtasy's Avatar
H-T Order of Merit
If you're buying tires, get 205/45-16 or 215/45-16.
If you're buying used wheels and they already come with 205/50-16, go ahead and use them if they don't rub. But when you need to replace the tires, get 205/45 or 215/45.
jksmith
Oct 21, 2009 10:34 AM
Platinum.Skillz
Oct 26, 2007 01:40 PM
12secferio
Jul 14, 2007 06:08 PM
AndrewJ
Nov 16, 2002 08:47 PM
JD_B18CDX
Jan 16, 2002 04:47 PM
