Starting Problems - I tried everything
Old Sep 10, 2002 | 07:19 PM
MechEng's Avatar
Default Starting Problems - I tried everything
My moms 92 Accord EX-R has problems starting when its hot out... it is
an intermittent problem (doesn't do it all the time) and usually starts after 4-5 cranks. It throws NO code.
It already has a full tune up: plugs,distributor....
I also replace the distributor bearing, and the ignition coil with no luck.
Any other suggestions, I'm confused.
Old Sep 10, 2002 | 07:23 PM
briq4's Avatar
Default Re: Starting Problems - I tried everything (MechEng)
Main relay is probably the problem. I've heard many people on this board state that is the problem I have a 93 EX and it did spaz out once but it was becuase the battery was practically dead. I could hear the relay clicking but it wouldn't let the car turn over.
Old Sep 10, 2002 | 07:25 PM
6GACCORDH22's Avatar
fuel pump relay . all 90-93 accords do it when they get miles on them
Old Sep 12, 2002 | 01:15 PM
MechEng's Avatar
Default Re: Starting Problems - I tried everything (98cpturbo)
On my 91 Civic is was the Main Relay, I didn't know Accord's have that problem
too?
Or is it the Fuel Pump relay?
Any other thoughts, I hate these intermittent problems... it seems Honda is famous for them.
Thanks
Old Sep 12, 2002 | 04:52 PM
The_In_Kid's Avatar
how much is that?
Old Sep 12, 2002 | 07:26 PM
91cordpos's Avatar
Default Re: Starting Problems - I tried everything (The_In_Kid)
I read on another board a thread that had 7 people saying that they had their main relay go out. Same exact thing. When hot out it wouldn't start all the time, but when it cooled off all was good again.
I say main relay as well.
Old Sep 12, 2002 | 07:48 PM
kentucky accord's Avatar
Default Re: Starting Problems - I tried everything (91cordpos)
main relay--60-70 bucks for part...10 minutes labor.
Old Sep 12, 2002 | 08:15 PM
CardDealer's Avatar
Banned
Default Re: Starting Problems - I tried everything (kentucky accord)
Modified by CardDealer at 4:17 PM 11/17/2006
Old Sep 12, 2002 | 08:17 PM
briq4's Avatar
Default Re: Starting Problems - I tried everything (schlit)
I don't know about the fuel pump relay idea.. I have 246,000 miles on my car and have only had the small main relay problem... Just my .02. I'd say check out the main relay.
Old Sep 12, 2002 | 08:20 PM
Default Re: Starting Problems - I tried everything (briq4)
the main runs the pump.
Old Sep 16, 2002 | 05:23 AM
MechEng's Avatar
If I disconnect the main relay it throws a fuel injector code,
so why doesn't it throw a code when the car doesn't start?
Old Sep 16, 2002 | 05:47 AM
CardDealer's Avatar
Banned
Modified by CardDealer at 4:16 PM 11/17/2006
Old Sep 16, 2002 | 05:49 AM
Accord94DX's Avatar
The circuit that goes bad is not connected to the CEL light. There are 8 connections on the relay, and the circuit for the fuel pump is the one that always goes. I work at honda, I saw probably close to 300 of these this summer.
Old Sep 16, 2002 | 07:55 AM
MechEng's Avatar
Default Re: Starting Problems - I tried everything (Me Love You Long Time!!!)
Thanks guys! Honda should have connected the entire relay to the CEL light,
it would have eliminated a lot of confusion.
Old Sep 16, 2002 | 09:35 AM
GSRMatt's Avatar
25 Year Member
Is this the same problem on a 99 4cyl Accord? Mine will occasionally (more often now) not run after starting. The engine fires almost instantly, runs for half a second, then shuts off. If I use about half throttle when starting it the engine tries to die in the same manner but fires again before all engine speed is lost.
I suspect the same thing is happening sometimes while driving. I'll be crusing along and it just shuts off. Sometimes it re-fires right away, other times I have to re-start the engine.
My problems seem to happen when the engine is cold, not so much when it is warm.
Old Sep 16, 2002 | 02:05 PM
Hi Ho's Avatar
Main Relay
This will tell you how to fix it yourself.
http://www.markl.force9.co.uk/howto/...main-relay.htm
Old Sep 17, 2002 | 03:32 AM
Charlie Moua's Avatar
Default Re: Starting Problems - I tried everything (Hi Ho)
haha as soon as i saw this post i knew what it was... funny thing though.. had the same propblem about amonth back. Search under Charlie in the accord form.... but like everyone else said it's your main relay. I took my 93 accord to Honda and let me tell you>>>expensive.
Taildragger22
16
Oct 28, 2016 05:53 PM
Tour2ma
Apr 17, 2013 02:00 PM
Origin
Dec 19, 2008 10:45 AM
red92EG
Jan 14, 2006 10:00 PM
mailforjon
Aug 20, 2002 10:40 PM
