Main Relay, common problem?
Old Jan 14, 2006 | 09:56 PM
red92EG's Avatar
Default Main Relay, common problem?
My brother's 94 Ls just died about two minutes after of running. I suspected the fuel pump, but a friend of mine told be that it could be the main relay. He had the same problem on his Del Sol.
Justed want to know is this an common problem among integras, especially over 100k.
Old Jan 14, 2006 | 10:00 PM
suzawa94's Avatar
Default Re: Main Relay, common problem? (red92EG)
the main relay is a very common problem for most hondas. usual symptoms are no start during hot temperatures or when vehicle is warm. it could be the relay, but should try to narrow the complaint down. does it die when warm? all the time? how do you know it's not ignition related? do you have spark? fuel? injector signal?
Origin
Dec 19, 2008 10:45 AM
DeviousCTR
Jun 28, 2006 03:43 PM
JDMdamian95
May 1, 2006 09:45 PM
flip1199
Feb 23, 2005 04:41 PM
