d16y7 pings
Old Sep 10, 2002 | 06:52 PM
RedEK's Avatar
Default d16y7 ping help
hey all...i know a decent amount of info on somethings but im not terribly familiar with causes of things...drive a 97 ek and it recently started pinging...ive done the obvious and ran like 93 octane in it changed the oil again and ran **** through both engine and gas...and for the most part it has quit but someties i can still faintly hear it...im pretty sure i have a rattle somewhere under the hood and im guessing its a head shield of sorts but as far as the pings should i replace the valves/valve guides or what..i just need some cheap options and opinions it would be greatly appreciated...its getting up there in miles approx 107k and hopefully within a year or two a swap of some sorts will be done...but in the meantime...please help me out.thanks
[Modified by RedEK, 4:18 AM 9/11/2002]
Old Sep 10, 2002 | 07:18 PM
RedEK's Avatar
Default Re: d16y7 pings (RedEK)
come one someone knows this ****
Old Sep 10, 2002 | 07:21 PM
4gvtec's Avatar
retard the ignition timming till it stops,it sounds to far advanced.
Old Sep 10, 2002 | 07:24 PM
RedEK's Avatar
Default Re: d16y7 pings (4gvtec)
ill give that a whirl...you dont think it has anything to do with the valves or anything? and it if helps I mainly heard it in 2nd through 4th gears
Old Sep 10, 2002 | 08:00 PM
Evs-One's Avatar
Solbros Owns Me
check ignition timing like he said. Shoudln't have to do with valves. But I would adjust them soon if you haven't recently
g1itchgsr
Mar 22, 2010 03:38 PM
DSRacing
16
Aug 1, 2007 09:19 AM
thad
Apr 11, 2004 12:48 PM
guymosiris
Jun 24, 2003 05:55 AM
tjtruong
Oct 26, 2001 10:33 PM
