porting intake and exhaust
Old Sep 10, 2002 | 06:46 PM
Nick H's Avatar
New User
Default porting intake and exhaust
has anyone done this, and if so how difficult is it to do by myself...i have access to the proper tools, and i'm not looking for a perfect cut or anything, as i know i am not able to do that, but it isn't something that needs to be perfect...anyways...i was just wondering who has done it and what kind of power value it is worth...i am doing this for preperation for a turbo on the f22b2...i want to make sure as much exhaust as possible is turning that turbo....
Old Sep 10, 2002 | 06:57 PM
Gennady's Avatar
New User
Default Re: porting intake and exhaust (nickh2k1)
Get a TB for $40 from Ebay and practice.
Old Sep 10, 2002 | 07:03 PM
niedejb's Avatar
Default Re: porting intake and exhaust (Wont be beat)
You can bore a t/b out all you want but you'll have to have a throttle plate made.
Unless you can practice growing them.
Old Sep 10, 2002 | 07:09 PM
Gennady's Avatar
New User
Default Re: porting intake and exhaust (niedejb)
Good point.
Maybe you can use an H22 plate.
Nick H's Avatar
New User
thanks fellas....
edit: also, how much do you suggest that i bore out the exhaust?...i was originally thinking about completely taking out the little fin in between the two seperate exhaust ports and making it one large hole that the two valves feed into collectively...any input on that, or would it be to big?
[Modified by nickh2k1, 11:12 PM 9/10/2002]
Old Sep 10, 2002 | 07:15 PM
ArchAngel Sabastian's Avatar
New User
* pshh whisper * h22 TB bolts up too f22 just port your intake plenum *pssh whisper*
and for an exhuast mod get rid of the stock o2 sensor housing replace it with somethin 2.25 or bigger but dont eliminate the spring bolts all together or youll tear **** up.
[Modified by Sabastian, 10:18 PM 9/10/2002]
Old Sep 10, 2002 | 07:21 PM
Nick H's Avatar
New User
Default Re: porting intake and exhaust (Sabastian)
thanks....
Old Sep 10, 2002 | 07:23 PM
Gennady's Avatar
New User
Pick up the Sept issue of GRM. 4 pages about head porting.
Old Sep 10, 2002 | 07:25 PM
New User
thanks....
no prob,
[Modified by Sabastian, 8:54 AM 9/11/2002]
Old Sep 10, 2002 | 07:39 PM
Ideal's Avatar
what is porting intake and exhuast?
jon
Old Sep 10, 2002 | 08:39 PM
Nick H's Avatar
New User
Default Re: porting intake and exhaust (Ideal)
the ports are the paths that the air and fuel or exhaust flow through...anyways, you can open these up to make them larger by grinding down the metal so that the air flows through the head more efficiently...that is a relatively simple explanation, but it works!
Old Sep 10, 2002 | 08:58 PM
GimpyAccord's Avatar
just thought i'd add that just hogging out ports isnt the path to more power..... even flow between ports is essential and knowing flow dynamics etc.. theres definatly an art to it. however cleaning up the ports and giving them a nice mirror polish on the exhaust side, and a semi polish on the intake is a good idea.
dont mirror the intake though, a lil rough promotes fuel/air mixture.
[Modified by GimpyAccord, 6:00 AM 9/11/2002]
2000Pimpinex
Jan 11, 2006 06:34 AM
Origin
Aug 29, 2004 03:45 PM
Accord6Gen
Aug 20, 2004 02:56 PM
love2xlr8integra
Aug 11, 2004 09:43 PM
pstreck
Aug 3, 2001 12:35 PM
