tranny problem
i just installed a new clutch now its making some grinding noises and you can hear here metal banging around
i installed the clutch with the flattest side towards the flywheel and used an alignment tool
cabe tranny
you can hear the grinding while sitting still and it gets worse if you try to put it in gear also grinds a lil and its hard to put it in gear
this is the first clutch i've ever done so im not sure what to expect
also how do you adjust it properly? ive messed with it and still no luck
the car is also on jack stands still but this wouldnt cause the problem would it? its on all 4 so the car is level
loosen the tension on the clutch cable until you can move your clutch fork up and down about a 1/4 inch or until the cable with the clutch engaged, pedal up, you can move the cable under the adjusting point a finger width back and forth.
TruenoMike14
Oct 22, 2013 11:36 PM
