Suspension setup for EK with h22?
Old Apr 21, 2010 | 04:08 PM
FearDisH22a4's Avatar
Default Suspension setup for EK with h22?
I Have a 96 EK hatch that im putting my built H22 into. Its a DX model so it has no sway bars at the moment. I Have Si front sway bar and lcas that im going to be installing. Im purchasing ASR subframe brace with 22mm CTR rear sway and Skunk2 lcas. Im pretty sure i would have to get the SI sway bar end links for the CTR rear sway. Im going with the ground control knoi setup. I called ground control about custom spring rates told and pretty much told them what my set up is going to be and that i was going to be using the car mainly on weekends and drag strip 2-3 times a month. They recomended 400 in the front and 380 in the rear. I just want to get a second opinion what do you guys think?
thanks
yvette
Diceclay
Suspension & Brakes
14
Feb 28, 2014 06:29 AM
Mfoehrkolb
Suspension & Brakes
Oct 12, 2010 04:32 AM
FearDisH22a4
Apr 25, 2010 10:08 AM
JDMThoughts
Apr 1, 2008 12:55 PM
EFstyle
Oct 17, 2006 05:05 PM
