brakes squeak
Old Apr 21, 2010 | 02:22 PM
Oknoe.'s Avatar
Default brakes squeak
my brakes make a high pitched screeching sound when i lightly press the brake pedal.
when i press it more firmly it seems to go away.
..the weird thing is that even when im not pressing the brake pedal at all.
and i give it gas, it'll ocassionally make a really annoying screech.
this has really been bothering me especiallly now that its getting louder and happening more often
is it time to replace my brake pads?
or can it possibly be something else?
Old Apr 21, 2010 | 02:28 PM
Oknoe.'s Avatar
Default Re: brakes squeak
it sounds like metal on metal
almost identical to this...
http://www.youtube.com/watch?v=kxdE1...layer_embedded
Old Apr 21, 2010 | 02:48 PM
vtaker's Avatar
Brakes usually squeak because the grease between the back of the pad and the caliper has washed away. This causes the brake pads to vibrate causing a squeak noise.
It could very well be that they are completely worn down too. I would check to see how much pad you got left. All you have to do is peek through the rim and check. Or you might need to pull the wheel off to see it.
Old Apr 21, 2010 | 04:10 PM
nsxtasy's Avatar
H-T Order of Merit
Actually, the most common reason by far for the brakes to squeak is because the brake pad material is too thin and the pads need replacing.
philkehn
22
Mar 8, 2023 11:11 AM
Xtream_V
15
Jun 24, 2007 09:46 AM
vlc92189
Mar 26, 2007 07:19 PM
bps2799
Dec 17, 2001 11:39 AM
RH+G
Jun 26, 2001 01:34 PM
