K Swap Parts! Hybrid Racing, Karcepts, Hasport | HA Motorsports
It's time for our K Series swap parts supersale at HA Motorsports! Check out everything we have to offer to help you finish your K-swap! Here's a brief list of what we have to offer. For other items, please feel free to visit us at www.hamotorsports.com
Hybrid Racing K Series Mount Kits
Hybrid Racing specializes in K series swaps and offers some of the finest K series mount kits on the market. These mount kits feature steel mounting brackets and hardware with billet aluminum mounts and tapered polyurethane bushing inserts. Default bushing stiffness is 75A and are a unique green color. The billet mounts have laser etched Hybrid Racing Logo's to set them apart from the competition.
Hasport Mounts
Anyone who has been around Honda's for more than a day knows about Hasport Mounts. Hasport has continued their legacy for creating uncompromised quality mounts with their K series mount kits. All Hasport K series mount kits come complete with required hardware for trouble free installation and have a lifetime warranty against defects and bushing deterioration.
Innovative Mounts
Innovative Mounts leads the industry in quality with their CNC cut billet mount kits and budget friendly black powder coated steel mount kits. The Innovative steel mount kits fit to perfection and feature the same high quality tapered bushings as their billet mount kits, but with a budget friendly price. For those who prefer the refined look, their billet mounts are sure to please. All Innovative mount kits feature a lifetime manufacturer's warranty!
Hasport Axles
Hasport Axles are built around the same great quality as their mount kits and fit great with the matching Hasport Mount kit. The Hasport stage 1 Swap axles are designed for the daily driver in mind. These axles will install with minimum headaches and easily withstand 200+hp engines. If you anticipate any competition racing or higher HP setup, please contact us as we can special order higher rated Hasport Axles for your setup.
Karcepts Shifter Mounting Kit
The Karcepts shifter mounting kit allows you to install your stock RSX K series shifter box below your center console. The adapter plate bolts under your shifter tunnel after cutting an access hole. The included silicone will seal the unit to prevent exhaust gas from entering your passenger compartment. Available for EF/EG/DC2/EK chassis.
Hybrid Racing Shifter Cables
The Hybrid Racing K series shifter cables are designed to significantly improve your shifting and eliminate the weak plastic joints found on the factory shifter cables. These feature improved construction throughout for increased shifting accuracy and shifter cable life. At around the same price as a new set of cables from Honda, there's no reason not to upgrade.
Hybrid Racing Bolt In K Series Shifter Box
This is the King of all short shifters. Designed specifically for K swaps, this Hybrid Racing bolt in short shifter allows you to bolt this unit into place without any cutting to your shifter tunnel. As if that wasn't enough, it allows 400+ adjustments to fine tune your shifting to exactly the way you want. PLEASE CONTACT US FOR AVAILABILITY
Hybrid Racing K Series Swap Conversion Harness
These Hybrid Racing K Series swap wiring harnesses greatly simplify your K series swap by allowing you to plug in your K series engine harness into your stock dash/cabin harness with ease. Step by step installation instructions make it painless for even those with very little wiring experience. Every Hybrid Racing harness is crafted with top quality wire and connectors for long term reliability and performance.
Hybrid Racing Immobilizer Removal Box
This is by far the biggest money saver for K swaps. The Hybrid racing immobilizer removal box will allow you to remove, or "bypass" the factory K series immobilizer eliminating the need to purchase a Hondata K Pro system. The immobilizer removal box wires in easily with the included instructions and can be neatly tucked away for a clean installation. Allows you to run your K series engine on the bone stock K series ECU.
EP3 K20 Idler Pulley Kit
This EP3 Idler pulley kit with belt will allow you to remove the factory K series power steering pump for proper hood clearance when swapping into any EG, EK, or DC2 chassis.
Karcepts K Series Clutch Line Kit
This clutch line kit is designed to allow easy installation into any EG, EK, or DC2 chassis with a K20 or K24 engine swap. The stainless steel braided line comes complete with all necessary fittings and is available for the standard Left hand drive chassis, or as a RHD/ tucked chassis length.
Hybrid Racing K Swap A/C Kit
Hybrid Racing A/C kits will allow you to connect your K series Air Conditioning pump to your swap chassis for proper A/C operation. You will no longer have to dread the heat when driving around town with your K swap. Available for 92-93 EG, 94-95 EG, 94-01 DC2, and 96-00 Civic EK.
| MANY, MANY MORE ITEMS ARE AVAILABLE 24/7 THROUGH OUR ONLINE STORE |
- Visit us at www.hamotorsports.com , or call 209-324-9880 -
HA Motorsports
209-324-9880
Hasport Mounts
Innovative Mounts
Hasport Axles
HA Motorsports
209-324-9880
Motor swap parts!!! Find everything you need for your K20 swap at www.hamotorsports.com
Hybrid Racing Fuel Rails are now available! Call us for more info 209-324-9880. These fuel rails fit on K series engines perfectly and make your fuel system install a breeze
