P1381 + P1399
Old Apr 20, 2010 | 03:29 AM
mtlr's Avatar
Default P1381 + P1399 please help!!
Hey guys,
FIrst i'll give you a description of my setup.
-JDM B18C
-Blox IM
-P73Canadian Ecu
-DC header
-High flow cat
All this in a 97 ITR shell.
Now here's the problem. I"m getting the P1381+1399 Codes together in tandem. sometimes i notice that when accelerating in 2nd gear from low rpm's the car "sputters"
I've done some searching and most threads point to the distributor or ICM.
I just replaced my spark plugs last week, the previous owner said he replaced the spark cables + distributer last year.
What should i be looking for?
Old Apr 20, 2010 | 10:25 AM
mtlr's Avatar
Default Re: P1381 + P1399
help?
Old Apr 20, 2010 | 10:33 AM
RICKSAUTOMOTIVE's Avatar
you can have the icm checked i believe at autozone but the 1399 is a valve clearance issue i believe. is you valve clearance good?
Old Apr 20, 2010 | 10:35 AM
mtlr's Avatar
where is the ICM? where can I find a pic?
Old Apr 20, 2010 | 10:43 AM
mtlr's Avatar
is it possible that the 2 are related?
Old Apr 20, 2010 | 11:11 AM
i've had multiple codes for the distributor...such as mis fires..cam sensor...ignition coil....icm.... but its been the dizzy. never had the 1399 with it. so IDK if the 2 could be related. i gotta look up the 1381 code cuz IDK it off the top of my head
Old Apr 20, 2010 | 04:18 PM
mtlr's Avatar
can someone give me an idea to where i should start looking?
where is the icm? and how do i check it?
Old Apr 20, 2010 | 04:20 PM
what year is your b18c from? 1999? do you have that distributor too? or a side mounted unit?
Old Apr 20, 2010 | 04:34 PM
mtlr's Avatar
the stamping on the head indicates that it is a 95. the distributor is mounted to the left. here's a pic;
i also just noticed my timing belt wobbles a bit when the motor is running, is that normal?
i should also mention that the car starts up perfectly fine, and idles ok as well!
Old Apr 20, 2010 | 06:15 PM
mtlr's Avatar
anyone know where I can find a write-up, on how to change the Dizzy? also, since my motor is a JDM B18C, can I just replace it with any v-tech distributor?
Drew082
12
Apr 30, 2016 05:16 AM
dynamitezz
Oct 28, 2006 08:07 PM
seifer
Jul 21, 2005 09:09 AM
B00ST2nR
Sep 22, 2002 01:00 PM
