suspension help
Old Apr 19, 2010 | 06:10 PM
doood's Avatar
been there done that
Default suspension help
here's the setup:
05 rsx-s
dropped on unknown springs and stock shocks (bought it that way)
2 finger gap front and rear
stock rims and tires
the steering wheel shakes above 70mph so i took it in for an alignment a few weeks ago and they said they couldnt do anything about the front but they fixed the rear. i forget the numbers but they werent horribly off either way. im confused as i've been reading old threads and everyone's saying that with a drop this small camber kits werent needed. so i guess what im asking is what's a good camber kit? im used to 5th gen civics and 3rd gen tegs so the rsx's macpherson strut design is still foreign to me.
and to add insult to injury, last week im on the highway doing about 65 when i hear a loud slapping noise coming from the front passenger side. pull over thinking it's a flat but there's no obvious puncture. pull the tire off and the inside edge was worn down so bad it went down to the belt and basically tore a strip about a foot long off and it was just hanging there. looked at the driver's side tire and it's worn down pretty bad too.
so now im down almost $600 for a new set of tires. and looking into camber kits. **** me.
Old Apr 19, 2010 | 09:00 PM
josh's ep3's Avatar
Function > Form
Default Re: suspension help
Sounds like the tires were the problem in the first place. Replace those and see how much better it gets. Tires can really make the biggest difference in ride quality.
Old Apr 19, 2010 | 09:59 PM
DaveSi677's Avatar
In what condition are the shock... if you are running stock shocks they won't last very long with a drop.
Old Apr 20, 2010 | 09:28 AM
mustclime's Avatar
speed related bounce is a tire.....get all 4 of them ballanced.
Old Apr 20, 2010 | 11:15 AM
nahonda04's Avatar
Surje.motorsports
your shocks are screwed....this is the same thing that happened to me, i couldnt get above 80 without the car shaking violently....bad shock and struts with lowering springs = new suspension setup.... oh and i would look at Ingalls front camber kit
Old Apr 20, 2010 | 05:07 PM
doood's Avatar
it's not a really violent shaking. at 70 the steering wheel vibrates slightly. as speed increases the shaking gets heavier.
gotta wait till tomorrow to get my tires. i'll see how it drives after that. i'll have to wait a little longer to get new struts but they're my next big purchase i suppose.
Old Apr 20, 2010 | 06:19 PM
cloumep3's Avatar
sounds like tire issue to me... please update after new tires
Old Apr 20, 2010 | 07:42 PM
doood's Avatar
here's what im looking at: http://www.clubrsx.com/cr/ING-RKIT.html
good buy?
Old Apr 21, 2010 | 04:09 PM
doood's Avatar
Got the tires replaced and no more shaking!
But I'm still looking at getting the camber kits
Old Apr 22, 2010 | 02:17 AM
azngotmilk's Avatar
if you need the front, i think this is fine http://www.clubrsx.com/cr/ING-81280.html
unless you upgrade your suspension and get camber plates
AnAccordIsForever
Suspension & Brakes
Jun 17, 2006 06:34 PM
no_life007
Suspension & Brakes
Dec 3, 2005 11:00 AM
cgap
Sep 12, 2005 07:50 PM
TEG98
Apr 6, 2003 08:33 AM
rsia23
Oct 8, 2001 10:07 PM
