b16a starting help
Old Apr 19, 2010 | 03:43 PM
zdub907's Avatar
Default b16a starting help
i have a 1991 integra swapped with a b16a.... i have everything hooked up except the extra wires that need to be run.... vtec selinoid, knock sensor, oil pressure switch and the 2nd o2 sensor..... it started the other day and sounded good and held idle good...... now it will not start up.... i used starterd fluid and it starts for a couple seconds then cuts off..... any suggestions!!!!!???
Old Apr 19, 2010 | 04:24 PM
zdub907's Avatar
Default Re: b16a starting help
tt
Old Apr 20, 2010 | 01:57 PM
93accordmike's Avatar
Bump
Old Apr 20, 2010 | 06:11 PM
92 CiviC H.B's Avatar
check if the fuel pump primes,have someone listen while you put the key to contact..if the car starts on start up fluid..its either out of gas or fuel pump is bad.
Old Apr 20, 2010 | 08:43 PM
well we replace the fuel pump but we pull the fuel rail off and try to start it to see if the fuel is going threw the fuel injectors but its not .....
Old Apr 21, 2010 | 06:31 AM
maybe the lines are clogged.
waynecoSI
Oct 2, 2008 04:04 AM
92 white eg
Aug 4, 2007 03:12 PM
nicko360
15
Jan 17, 2007 06:22 PM
civic89si666
Jan 31, 2006 05:22 PM
