Using a mix of E85 in my 2003 Acura TL with NO problems
I have been blending E85 (85% Ethanol) in my 2003 TL for YEARS and it runs great. I currently have over 147k and it still runs like a champ on E30. Don't worry, you do not need to change fuel injectors to run E20 or E30.
My car loves the higher octane that E85 has (105 octane). I blend it with
E10 to get E30 that has a 92 octane rating.
Don't be afraid of adding a 2 - 3 gallons of E85 on every fill up.
Start out with 1 gallon only since it will take the varnish off that gasoline has left behind.
2 x 85 = 170 (2 gallons of E85)
8 x 10 = 80 (8 gallons of E10)
170 + 80 = 250
250/10 = 25% Ethanol.
2 x 105 = 210
8 x 89 = 712 (89 octane rating of mid-grade)
210 + 712 = 922
914/10 = 92.2 Octane Rating
Compare "super" (not regular) to the cost of E85 and you will see that by blending you will reducing your fuel costs and raise the octane rating.
170 + 80 = 250
2 x 105 = 210
210 + 712 = 922
Also I don't think your math is right. I'll check it tomorrow in my fuel blend spreadsheet. You need to do things on a mass basis not volume so you'll need the density of gasoline (which tends to vary a lot by season) plus the fact that gas stations already add up to 10% ethanol but not always the full 10% and your calculations are a guestimation at best.
The math may be fuzzy but it works. The TL can take up to 33% Ethanol using that formula. I did figure that the gas I use is E10 or 10% ethanol. This forumla works. If I go over the 33% I will get a check engine light to come on. So I bring the concetration below 33% (using the fuzzy math) and reset the code and all is well.
Since there are only like 18 gallons of gas in a barrell of oil. So by using a higer concentration of Ethanol we reduce our (USA) dependance on foreign oil. Brazil did and we can too.
