Need a little help suggestions on coilovers?
Old Apr 19, 2010 | 07:41 AM
JonoBB6's Avatar
Default Need a little help suggestions on coilovers?
Hey Im new to the Honda-tech forum and was just looking to get some suggestions...
I have a '98 prelude bb6 and its slammed on like a 2 1/2 inch drop (guy before me did it) and I am looking at redoing the suspension so its not completely destroyed, just wondering if anyone had any good suggestions on brands or anything to help me with some ideas, thanks
Old Apr 19, 2010 | 07:47 AM
bajasti's Avatar
Default Re: Need a little help suggestions on coilovers?
yes...check out the tein basic damper setup.. i love it. best ride quality and look from my experience....beware of low cost knock off brands as they will be troublesome..
Old Apr 19, 2010 | 09:39 AM
NirVTEC's Avatar
You can't go wrong with Koni/Ground Controls.
Just be wise picking your spring rates.....
I can tell you that 400F/400R is a bit aggressive for a street car.
They will probably offer you the OTS 380F/275R which should be just fine.
Old Apr 19, 2010 | 01:16 PM
bad-monkey's Avatar
+1 on the Ground Control/Konis.
400/400 won't be too bad. I think I was on 450F/550R when I was auto-x'ing/tracking my lude alot. I daily drove it too, and while stiffer than stock, the koni's handled the spring rates fine. 380/275 also works.
Old Apr 20, 2010 | 05:54 AM
JonoBB6's Avatar
thanks guys Ill keep my eye out
Old Apr 20, 2010 | 06:12 AM
mugen22's Avatar
What are you planning to do with the car?
If it is purely a street car and you want a 1.5-2" drop, I would strongly suggest looking into Koni Sports with either an Eibach Pro-kit, H & R Sports (both about 1.5" drop) or H & R Race (about 2" drop) springs. If you are planning to Auto-x and/or go to track days, then as mentioned, Koni/Ground Control is a great way to go. Notice the common theme here is Koni Sports?!!
Hope that helps,
Brian.
Old Apr 20, 2010 | 07:44 AM
Tweaked's Avatar
Im using Ground control with koni shocks I love them, smooth ride with any ride height and you can adjust the stiffness with the shocks and the konis have adjustable perchs too. Here is a pic of my set up
Old Apr 20, 2010 | 10:40 AM
NirVTEC's Avatar
Hope that helps,
Brian.
The perfect reply....
Konis are the key. Most people would be shocked as to how much just turning the dial affects the ride.
We have a rippled HWY out here that is awful with the Konis on stiff, turn them to soft and its a whole new world.
Old Apr 20, 2010 | 01:21 PM
A Blue Lude's Avatar
I still find the ride ok with the shocks turned down on 650F/450R.
Ground Controls are a affordable way to give yourself a lot of flexiblity - ie, get your ride height to where you want it, choose your spring rate (and re-choose it at just over ~$60 a spring).
But they're a bad idea for a car that sees rust-belt winters, or has an owner that doesn't care about adjustments and wants simplicity. In that case a regular lowering spring might be a better idea.
Old Apr 20, 2010 | 01:35 PM
NirVTEC's Avatar
Honestly, on the cheap, a Tokico/Eibach combo would please most drivers.
I rocked it for years and was happy.
Old Apr 20, 2010 | 07:31 PM
carfanatic98's Avatar
koni/ground controls.
or kyb shocks with skunk 2 springs, thats what i have on my car, a comfortable 1.5" drop
Old Apr 21, 2010 | 04:42 AM
autoluder's Avatar
ZEAL FUNCTION S6, haha, too expensive, but bonus points to who can answer what lude uses those.
Actually I have Koni/GC too
420lb front
380lb rear.
Old Apr 21, 2010 | 06:35 AM
NirVTEC's Avatar
420lb front
380lb rear.
JUN
Old Apr 21, 2010 | 06:43 AM
JonoBB6's Avatar
Im more or less just going to daily the prelude but on weekends and **** I wanna go out and have fun in Im not looking for some cheap **** Im looking just for a decent set to get me started, I have been looking at the Konis adjustables and will probally go with those. thanks for all the help
Old Apr 21, 2010 | 06:56 AM
Josh Vertiz's Avatar
Old Apr 21, 2010 | 07:12 AM
NirVTEC's Avatar
Koni/GCs for sure then.
Just a little heads up(I was told this years ago, makes sense) Don't turn the adjustment **** all the way to one side, back it off 1/8-1/4 turn.
Old Apr 21, 2010 | 07:39 AM
JonoBB6's Avatar
gotcha thanks for the advice Ill get some pictures up when I get them in
GSR615
Suspension & Brakes
Jun 13, 2010 05:48 PM
evillesi
Nov 28, 2006 02:28 PM
CTR-GSR
Suspension & Brakes
Oct 3, 2006 07:15 AM
TrueZen
Nov 25, 2002 08:49 PM
