Fuel pump not getting power
Old Apr 19, 2010 | 07:23 AM
redline1320's Avatar
Default Fuel pump not getting power
I have a DB8(95-4dr gsr) integra and i've not been able to get the fuel pump to get power from the stock plug only through straight wire....so far i've checked all the fuses(under dash for main relay and under hood) and I thought the main relay was good cause I feel it click when I turn the key over but it won't get power to the pump, so I tried jumping pins 5 and 7 and the fuel pump got power so I replaced the relay and still no power anyone got any ideas?
Old Apr 19, 2010 | 08:42 AM
blackcracker's Avatar
Default Re: Fuel pump not getting power
check and see if you have power coming from the wire in the main relay....Like check the wire that goes from the relay to the pump...maybe the wire is burnt out.
Old Apr 19, 2010 | 09:01 AM
Im going to do a slight snip to check for power going out from the relay, but I don't think the wire to the pump is burnt becausewhen I jumped pins 5 and 7 the fuel pump immediately turned on
Old Apr 19, 2010 | 09:26 AM
http://www.tegger.com/hondafaq/mainr...ion/index.html
try taking a look at that. It shows you how a main relay works. If everything checks out ,its probally something in the wiring.
Old Apr 19, 2010 | 09:38 AM
Alright reading it now thanks!
Old Apr 19, 2010 | 11:08 AM
ef9er0's Avatar
r u getting power from the fuse box? i had the same problem and the fuse box under the dash burned out
Old Apr 19, 2010 | 12:48 PM
Ya just a bit ago I looked at the diagram for the main relay and noticed pin 8 has to ground out for the fuel pump to receive power so I sliced the wire open and ran a wire off it to ground it to basically see if the relay was opening when grounded to get power to it and it was the fuel pump immediately turned on and off when I removed the ground so im assuming my problem is in my ground wire that runs to the ecu so it can control when it gets power or not? Or am I missing something..
Old Apr 19, 2010 | 02:23 PM
your on the right track.
Old Apr 19, 2010 | 02:33 PM
Well I guess my next step is to remove my dash to follow the ground all the way to the ecu...
Old Apr 19, 2010 | 06:30 PM
multimeter would help you do that with out taking the dash out..
Old Apr 19, 2010 | 08:37 PM
true.
Old Apr 21, 2010 | 08:32 AM
Happen to know where any diagrams might be or know if the ground from the relay (pin 7 that the ecu grounds to give power to the fuel pump) is a straight wire to the ecu?
Old Apr 21, 2010 | 02:41 PM
LS-T_FTW's Avatar
i am having the same problem... is your cel is on ? mine isnt and all my grounds are good, all the fuses are good, fuel pump is good, main relay is good.... im stumped
Old Apr 21, 2010 | 05:53 PM
nah my cel isn't on...I'm still convinced its my ground to my ecu.
Old Apr 21, 2010 | 05:57 PM
check the engine thermo ground....
Old Apr 21, 2010 | 05:59 PM
you should be able to use your helms manual if you have one.....There is diagrams in the back...
Otherwise google is your friend.
But im pretty sure the main relay powers the-PUMP,ECU,and accc.
Old Apr 21, 2010 | 06:30 PM
well have the manual and found a pin out just figuring out which pin is it found which is for the fuel pump but not sure if its the power or ground so just stuck figuring that out.
Old Apr 23, 2010 | 04:58 PM
here this might help...
http://www.phearable.net/tech/wiring/pinouts2.htm
also....try using a aligator clip and clip it to the relay and then to the wire on the pump...If you click the key and it works, you have a dead wire......
Old Apr 27, 2010 | 06:55 PM
Well I figured out the problem after all the looking it turned out my ecu fuel pump circuit shorted out... fail
Ri5e
Jun 4, 2024 08:52 AM
brian91accord
Aug 25, 2011 04:18 PM
jaerikd
Oct 6, 2009 08:10 PM
boosteddohczc
10
Jun 11, 2009 09:57 PM
0817crx
Sep 18, 2005 08:00 AM
