Valve Tic still there!
Old Apr 19, 2010 | 07:02 AM
andlude's Avatar
Default Valve Tic still there!
So I adjusted my valves and everything is where it's supposed to be but I'm still getting a loud tic when the motor's running. Is there anything in the valve train that is notorious for wearing out fast and maybe leaving to much play? I want this noise gone asap. Thanks
Old Apr 19, 2010 | 09:27 AM
red92si's Avatar
Default Re: Valve Tic still there!
LMA's
Old Apr 19, 2010 | 12:47 PM
minilogoguy18's Avatar
^x2
I'm about to do mine once I start this job at a Honda dealer where I can just do it after work, there's a great writeup on here somewhere that was shown on a B18c but the process is the same for us. If you have an OBD1 H22a best thing would be to order the newer style for the H22a4 and shim them with a hardened steel washer that's 12mm diameter, 2mm thick, it's cheaper than ordering H22a1 ones that don't last as long. <-Credit to Pirate for filling me in on that.
Old Apr 19, 2010 | 09:01 PM
Lude Acts's Avatar
http://www.inlinefour.com/imoembvtlomo.html
It says B18, but they are available for the h22a also.
You're welcome.
Old Apr 20, 2010 | 01:45 AM
E-Money's Avatar
the price on those aftermarket ones is ridiculous. on a wholesale oem site they are 8 dollars a piece..
Old Apr 20, 2010 | 04:02 AM
Also it just has H22a listed when the OBD1 and OBD2 heads have different length LMA's hence the need for a shim when using H22a4 spring types in a OBD1 head since they never updated the OBD1 H22a ones.
Old Apr 20, 2010 | 06:08 PM
extrudelude's Avatar
I've had the same problem for a while and it is sooo annoying. I have a OBDI head in my 97, so I took out the LMA's from a newer head I had in my garage and shimmed them up. I either didnt shim them up enough or the used ones were also worn out because it didnt fix the problem. If you have an OBDII head, just get the ones from honda. If you have you have an OBDI head, get the spring type for the OBDII head and shim them up with washers. And make sure you get new LMA's and not used ones like I did, it is a pain in the *** to swap them out.
Old Apr 20, 2010 | 11:22 PM
kornkid21792's Avatar
guys our engines naturally have a loud valetrain you might just be overthinking this
Old Apr 21, 2010 | 08:30 AM
su8854's Avatar
do valve audj, i think manual is .06 intake and .07 exhaust.... i did that and i got the ticking too..... but a pro tuner told me about how wear and tear effects that esp if you race with the engine, i did it .05 intake and .06 exhaust and absoutly no more ticking noises....
Old Apr 21, 2010 | 09:37 AM
^Then how do you explain my car that has virtually no wear and tear with a fresh H22a that has only seen vtec 3 times to test the wiring?
Old Apr 21, 2010 | 04:04 PM
su8854's Avatar
:S wiring?
Old Apr 21, 2010 | 07:02 PM
I swapped from a H23a1 and wanted to make sure everything worked right so I followed the Helms procedure for testing the VTEC system, 2nd gear, half throttle til red line.
cpmike
Mar 31, 2007 08:24 PM
vti-R
Jul 12, 2004 05:40 AM
flashmang
Jul 6, 2004 09:58 AM
se93
Mar 20, 2002 06:17 PM
