HONDA PARTS B & D SERIES
I have alot of misc. honda parts that have accumulated over the years and now im in need of getting rid of them~!
texting is the easiest way to reach me otherwise call if i dont answer then please leave a message.
469-360-8420 Jason
pickup only no shipping
D series parts
D16Z6 cylinder head good head needs valve stem seals missing a few bolts $50.00
D16Z6 fuel rail $5.00
D series trans torque bracket w/o mount $10.00
92-95 civic rear T bracket SOHC $10.00
92-95 civic power steering pump 25.00
96-00 sohc power steering pump 25.00
D series A/C compressor bracket $10.00
D16Z6 lower timing belt cover $10.00
D16Z6 harmonic balancer $10.00
D16Z6 power steering bracket
92-00 SOHC stock clutch x2 25.00 ea
92-95 EG stock air box and intake tube $15.00
DEL SOL SI rim x1 $10.00
88-91 CRX civic HATCH WASHER FLUID RESERVOIR $20.00 no cracks or breaks
92-95 stock upper control arms all four corners $30.00
CRX WASHER FLUID RESERVOIR NO BREAKS. 10.00
B SERIES PARTS
00 TYPE R CYLINDER HEAD COMPLETE 1000.00 obo
00 B18C5 block needs rebuild smokes/slight knock 400 obo
timing cover behind the cams P72 $10.00
b series trans torque mount bracket w/o mount $10.00
b series OEM a/c compressor 50.00
B series alternator $40.00
numerous b series ac brackets P30, P72, P73<~~~type r 25.00 each
INTEGRA B pipe stock $10.00
B series front mount bracket for eg-dc{the one on the timing cover side} $15.00
B series upper power steering brackets x3 $5.00ea
RANDOM DSM PARTS
4G63 coilpack assembly free if you buy anything above
4G63 throttle body assembly free if you buy anything above
thermostat housing free if you buy anything above
DODGE STEALTH DOHC STOCK omni spark PLUG WIRES NEW 10.00
CALL OR TEXT 469-360-8420 Jason
469-360-8420 Jason
D series parts
B SERIES PARTS
RANDOM DSM PARTS
