Cluster stopped working after Thermostat install
Old Apr 18, 2010 | 02:53 PM
DumaDA's Avatar
Default Cluster stopped working after Thermostat install
ok guys need some help, i just changed my thermostat, just simple remove hose, remove housing and thermostat, replace, add coolant, start car and it was fine all of a sudden i walk back to check it out and my gauge cluster isn't working, the temp, rpm, and speed are not working, so i turned the car off and put the key to the on position, the only light that turned on was the battery light, what could it be guys?
Old Apr 18, 2010 | 03:38 PM
DumaDA's Avatar
Default Re: Cluster stopped working after Thermostat install
just drove, speedo works, everything else does not, not even the seat belts or signals
Old Apr 18, 2010 | 08:34 PM
Slain's Avatar
check fuses
Old Apr 19, 2010 | 01:08 PM
DumaDA's Avatar
checked my fuses and they're good, checked the grounds and they look fine
Old Apr 19, 2010 | 01:58 PM
mouab18c1's Avatar
Redo the process again? You could have shocked a wire
Old Apr 19, 2010 | 02:09 PM
DumaDA's Avatar
im going to head to my friend house after i get off work and see if they can figure out the problem, hopefully it all gets sorted out, i cant drive too much if i dont know how much gas i have..
90DB1TegSedan
Sep 5, 2012 10:44 AM
Stunna MIKE
Feb 23, 2012 06:50 PM
projectr
Dec 2, 2008 06:47 PM
ltran82
Nov 1, 2007 12:58 PM
SloCivicHMM
19
Dec 10, 2003 03:36 PM
