Sportmax 002 16x8s on 98 lude..
16x8 should not be a problem if the offset is +40 or greater. You might need to roll the fenders front and rear, depending on the tire you choose. Rear will need to be rolled more than the front, if you need to roll the front at all.
+0? Rolling won't be enough. You'll have to get someone to mold fender flares for you.
I'm running 17x8.5 +40 wheels and with 245 wide race tires, the front fenders barely work with rolling (and lots of negative camber), and I'm still not sure if I can get the rears to work without serious modifications.
Well I don't mind doing some fender rolling but don't want 2 get fender flares.. Do u think I can get away with +15 offset I want some with a lip I had some 501 sportmax on this 99 mirage ls.. Never rolled fenders but it would rub a lil.. They were 15x8.. What can I get away with?
Hella_Fresh
Mar 10, 2007 01:31 AM
juice91si
Mar 21, 2006 06:59 PM
