power steering help :)
i have a b18b in my 93 civic si hatch and im getting a 99 civic si powersteering pump but i need to know what bracket i need for the pump to mount to? and will my civic si power steering rack work with everything?
ty
ty
You need both ls brackets. Also do note the 99-00 si pump is obd2 which might have the diffirent ps line hole on the pump. There are 2 versions. OBD1 and OBD2. They have diffirent ps lines. Get yourself a LS pump or rs or whatever. As long as its obd 1
Here read this.....even though you dont have a EK itll help clear things up a bit. Of what i said.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-retaining-power-steering-ek-b-series-swap-1822781/
the em1 powersteering....is a vtec powersteering braket so you have to get a obd1 ls braket so it would work also you need a ac ls braket cus it throughts your torque off.....you shuld go to the junkyard & get both off a obd1 ls longblock......good luck bro
ohsnapzafingcu
Dec 8, 2008 07:22 AM
JussHatched
Apr 24, 2006 07:53 AM
