Do you need a press to do a rear wheel bearing on a dc?
i dont belive you do.. should be 4 bolts on the back side of the hub...(i know it was when i did my ej1 a few months ago. just unbolt pull out the hub bearing/spindle and replace with new one...
edit: and the acura shop manual says nothing about pressing the assembly in or out. If you needed a press if would state that explicitly, right? Just double checking because I only have so much use of a lift and if this turns into a project I'm SOL.
MarkCayabyab
Oct 7, 2017 11:40 AM
eg:R
10
Oct 15, 2011 02:15 PM
PaChiLa Leader
Feb 18, 2009 05:21 PM
pcorad
May 30, 2002 12:36 PM
