GSR LSD trans?
Old Apr 16, 2010 | 07:13 AM
i-VTEC_do_you's Avatar
Default GSR LSD trans?
I'm looking for a GSR LSD tranny for my ek and i need to know the tranny code for the OBD2 version 98-01. Does anyone know?
Old Apr 16, 2010 | 07:43 AM
300whpej's Avatar
Default Re: GSR LSD trans?
http://www.jdmcars.com/tech/admin/bseries_tranny.pdf
Old Apr 16, 2010 | 07:44 AM
Deetz's Avatar
Crazy Honda Guy
Can't recall the code off of the top of my head, but i can tell you the only gsr gearbox to come with lsd was an option on jdm spec models. No usdm gsr ever had the option
Old Apr 16, 2010 | 07:49 AM
Deetz's Avatar
Crazy Honda Guy
That may not be the best source. I just took a quick peak, and it is missing loads of info, starting right from the cable tranny's
No mention of A1, J1, S1, and the jdm spec YS1 with lsd options....and that was just the 1st section.
Old Apr 16, 2010 | 07:57 AM
300whpej's Avatar
true, but it did tell how to spot a lsd from a non lsd tranny, along with some other tidbits i found useful
Old Apr 16, 2010 | 08:17 AM
Deetz's Avatar
Crazy Honda Guy
It's all good....this may help the OP to ID the proper tranny
Old Apr 16, 2010 | 09:04 AM
93egSLEEPER's Avatar
If you do find a gsr w/ factory LSD more then likely you will end up with the JDM gsr tranny. I cant recall if that has the gears of the ITR/B16 or usdm GSR gears which are a bit longer. Deetz can probably expand on this.
i-VTEC_do_you
Apr 16, 2010 07:51 AM
tvrsir
Jul 28, 2004 04:17 AM
CR-V-tech
Oct 29, 2003 05:37 AM
Hondasaurs
May 2, 2003 06:03 PM
. o 69 o .
Jan 19, 2002 11:15 PM
