98 Civic EX Road trip ok with camber?
Hi guys, I'm planning a road trip on my 98 Civic with 122k miles. I lowered it on Eibach pro kit and shocks 2 weeks ago. I went in for an alignment today to fix my toe but camber in the rear is -2.1 and -2.3. Fronts are ok. I'm wondering if that degree of camber is bad and should I be ok for a 1000 mile round trip? Tires are at 70% Also if I do the washer trick to get back some + camber, will this mess up my toe again which I believe is worse then camber? Which trade off is better? Thanks in advance.
it's def gonna throw off your toe when you add washers now. you should've added them first before you had your alignment.
anyway, if the toe is good, the tire wear won't be bad.
http://cgi.ebay.com/ebaymotors/ws/eB...2337&viewitem=
This is the guy I bought the kit from. Delivered really fast and everything was in fantastic shape. Takes about 2 hours to put the kit on if you know what you're doing. You might have to make clearance for the A arm as it may be a little bigger that OEM. I just had to bend a little fender seam and it cleared just fine. I promise you won't be disappointed.
ridnmyhonda
Mar 19, 2002 05:13 PM
