no spark and no check light.
my friend has a 94 acura integra ls and we put a jdm b 16 in long time ago. all the sudden the car stoped working and there is no spark. we changed the coil and the module and still no spark. the engine check light is only throwing code 21 which is vtec and thats it. what else could be the problem. also when i took the spark plugs out it was really black and smelled like gas.
when you say bad brain, you mean the ecu? i changed the ecu but still didnt start. the cap and the rotor seems fine. so i am just left with replacing the distributor. is there anything else that could cause no spark?
ef2 from hell
Nov 25, 2006 03:07 PM
