Sad Day for my REXY =[
Old Apr 15, 2010 | 09:31 AM
SeeAreEx!'s Avatar
Default Sad Day for my REXY =[
Small Dilemma!
i have a stage 2 clutch in my 89 crx si. but everything in that car CANNOT withstand the stiffness of the clutch. First i had a problem with the Clutch Cable Bracket. i had to replace that and reinforce it!
Now i have a problem with the bracket that the clutch PEDAL pivots on
i went to start the car in the morning and the son of a gun just SNAPPED!!
now i wanted to get sum opinions. Should i completly remove and replace it.
or should i keep that bracket and weld it and REINFORCE that!
thanks guys!
o and ps....I AM PLANNING ON KEEPING THE CLUTCH!
Old Apr 15, 2010 | 10:45 AM
1991civicsi's Avatar
Default Re: Sad Day for my REXY =[
Reinforce the bracket, it a common problem with a HD PP
Old Apr 15, 2010 | 11:01 AM
jonnyt1130's Avatar
lol .Happened to me when I put my clutch in my crx. Just remove the pedal assembly, bend it back into place, weld some fat beads around it, and re-enforce it with some brackets. I havent had a problem since.
These links helped me when removing the the pedal assembly.... https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/manual-pedal-cluster-auto-car-1220898/
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/clutch-pedal-broke-my-91-civic-attempting-fix-myself-need-some-help-2482239/
btw when welding it watch out the bushings, they melt easily.
Old Apr 15, 2010 | 02:29 PM
SeeAreEx!'s Avatar
thanks a lot guys..ill look a little more into the guide on how to remove the bracket this weekend when i have more time.
Hankish
Feb 25, 2007 08:57 PM
syntax.
Jul 14, 2006 10:03 AM
jdm206
12
Feb 21, 2006 03:22 PM
[626]95-GSR
11
Mar 29, 2003 09:13 PM
[626]95-GSR
Mar 27, 2003 10:49 PM
