EG, EK, DC Storage Unit Clearance
Old Apr 14, 2010 | 10:32 PM
xlasianizelx's Avatar
Default EG, EK, DC Storage Unit Clearance
Clearing out my storage unit.
Lots of random and useful parts.
All are located in San Francisco
92-95 Honda Civic
* Hatch / Coupe A Pillars .................................................. ............................. $10
* hatch Rear Trunk Pannels (priced for each pannel)........................................... . $5
* black lower steering colum cover .................................................. .................$5
* lower knee pannel (black, no fuse cover) .................................................. ..... $10
* Front Pair wiper arms .................................................. ............................... $10
* Driver Side fender side moldings (each)............................................ ............... $5
* Rear lower control arms (pair)............................................ ........................... $30
* Front Upper Control arms (pair)............................................ ......................... $30
* Rear Upper control arms (pair)............................................ .......................... $30
96-00 Honda Civic
* Driver Side Door Handle/ window switche .................................................. ...... $10
* Driver Side Power Lock trim.............................................. ............................. $10
* JDM CTR Airvent Coin Pocket (pocket cut for turbo).......................................... $20
* Keyless Rear Door handles (stripped paint)............................................ ........... $30
* Driver Side Door handle (white)........................................... ........................... $15
* EX Cruise Control Unit (dinged but worked fine when removed)............................ $20
* ECU Kick Pannel Cover .................................................. ...............................$10
* Sedan Driver side tweeter delete .................................................. .................$5
* Knee Pannel w/ coin pocket, sunroof, mirror and foglight switches(no fuse cover)...$30
* 96-00 Civic EX Brake proportional valve (good upgrade for disc brakes).................$20
* 99-00 Civic CF Mugen Lip(1 crack but reinforced)....................................... .......$100
* Coupe Clear front window glass (pass & driver)........................................... ......$100
* Coupe Trim Black License plate panel .................................................. ........... $20
* Washer fluid resivoir w/ pump .................................................. ..................... $20
* Front lower splash guard .................................................. ........................... $20
* 99-00 Civic Si Center Console Switches (no bezel, lights amber)......................... $75
* OH SH*T Bar handle .................................................. ................................. $10
* ASpec JDM EJ8 License Plate .................................................. ..................... $25
* JDM Domani OEM Metal hood .................................................. ..................... $80
94-01 Integra
* Stock Clock (unknown condition)........................................ .......................... $10
* JDM ITR Rear LCA .................................................. ................................... $50
* JDM 96' Spec ITR Front Calipers w/ bracket .................................................. .. $80
* JDM 96' Spec ITR Rotors 4x114 (hotspots, need resurface).............................. $40
* GSR Optional Exhaust tip .................................................. .......................... $25
MISC:
* JDM RHD Fuse Box .................................................. .................................. $40
* BNIB Brembo Covers .................................................. ............................... $25
* PIAA Projector Foglights (no mount or harness, light up yellow) ........................ $30
* 17" Yokohama Advan A048 (pair, about 10-20%, good for track use)..................$100
* Benen / Datum Tow hook Lug nut Lock Kit .................................................. .. $15
* Bell Triple Back Bike Rack (trunk mount, like new, used 3 times) ........................ $30
* V-Spec Racing Front Coilover Sleeves (MADE IN JAPAN) .................................. $60
* 10" JL Audio 10w3v3d4 Sub in Box (sub has a small puncture) .......................... $75
* 4x114 Full Size Steelie 195/50/15 tire .................................................. ........ $30
* 24 Led SMD Board (dome light, for wedge & tube fitments)............................... $20
* 12 Led SMD Board (dome light, for wedge & tube fitments)............................... $15
* 6 Led SMD Board (dome light, for wedge & tube fitments) ................................ $12 (new)
* 8 Led SMD 168 Wedge (Pair) .................................................. .................... $12 (new)
* 4 Led SMD 168 Wedge (Pair) .................................................. .................... $12 (new)
* Used Apexi EL 60mm Boost Gauge .................................................. ............. $60
* Used Autometer Carbon Fiber Boost Gauge 52mm ........................................... $30
* Used Greddy 60mm Air Fuel Ratio Gauge .................................................. ..... $100
* Glowshift Universal triple 60mm pillar .................................................. .......... $25
* Hondata Boost Solenoid .................................................. ........................... $50
* Iphone 3g Jailbroken 8gb .................................................. .......................... $175
CENTER CAPS:
Effect Wheels (bnib, w/ stickers) .................................................. ............... $20
Buddy Club P1 Racing II Plus (missing 2 outer caps) ........................................ $25
Optional Acura Emblem .................................................. ............................ $30
949 Racing 6ul (BNIB) .................................................. ............................. $25
AP1 S2000 (Pair) .................................................. ..................................... $20
Rota (only 3)................................................ ............................................. $15
Engines:
* USDM 94 B16a3 Short Block Complete -.................................................. ............... $400 legit
* USDM 99 B16a2 Long Block Complete -.................................................. ................ $800
WTT/WTB:
* 60mm oil pressure gauge
* missing link
* 1.5, 2 or 3 bar map sensor
* hondata p28 w/ s200 or s300
Old Apr 16, 2010 | 09:41 AM
Project-Honda's Avatar
Default Re: EG, EK, DC Storage Unit Clearance
what size are the advans?
Old Apr 16, 2010 | 05:20 PM
225/45/17...
Old Apr 16, 2010 | 05:46 PM
JDM_WHR's Avatar
bump
Old Apr 16, 2010 | 06:36 PM
System Lord's Avatar
Old Apr 16, 2010 | 11:32 PM
ty ty
Old Apr 17, 2010 | 10:12 AM
bump
Old Apr 17, 2010 | 05:54 PM
bump
Old Apr 25, 2010 | 04:42 PM
bump
Old Apr 27, 2010 | 05:42 PM
bump
Old Apr 27, 2010 | 08:30 PM
jdm96db8integra's Avatar
ik want ur 16's time attacks..and brembo covers!.. i got gsr blades.. jdm itr header 98 specd 4 to 1.. torn up recaro.. complete with sliders and rails.. 00 civic si ecu..
also.. whats the mileage and condition on the 99 usdm b16a2 motor? u got a bill of sales or the title to the motor?.. the vin still on the block?.. what comes with the complete longblock u have?
Old Apr 27, 2010 | 09:27 PM
Pensar71's Avatar
Bump for pics of the motors.
Old Apr 29, 2010 | 05:58 PM
bump
Old Apr 29, 2010 | 06:00 PM
not really looking for those to trade...
as for the b16a2.... motor came off my buddys 00 si but was missing the vin on the block... not too sure....
Old Apr 29, 2010 | 09:24 PM
trickk's Avatar
willing to trade blades for meshes brand new tires. pm me
Old Apr 30, 2010 | 11:09 PM
bump
Old Jun 14, 2010 | 09:44 PM
BUMP
Old Jun 15, 2010 | 09:49 AM
Rhetoric's Avatar
still got the gsr optional muffler tip?
Old Jun 16, 2010 | 12:38 AM
yup
Old Jun 17, 2010 | 01:07 PM
bump
Old Jun 18, 2010 | 11:00 AM
bump
Old Jun 19, 2010 | 06:19 PM
NorCal EM1's Avatar
What brand is the 'mugen' lip? any better pics?
Old Jun 19, 2010 | 10:33 PM
unknown brand...
Old Jun 19, 2010 | 10:34 PM
bump... new items added....
Old Jun 21, 2010 | 10:38 PM
bump
