type r swaped gsr need some help
Old Apr 14, 2010 | 05:57 PM
benmyfriend's Avatar
Default type r swaped gsr need some help
i have 99 db8 and im puting in a type r motor. im having trouble finding the right heater hoses for this car. the specific hose im looking for goes from the heater valve to the the head of the motor. the heater valve that is on the car doesnt seem to be the normal one either. the other heater valves ive seen are 45 degress from the firewall but mine is parallel so that means the hose needs to be longer. does anyone know which hose i should buy?
thanks for the help
Old Apr 14, 2010 | 06:22 PM
mouab18c1's Avatar
Default Re: type r swaped gsr need some help
Any rubber hose with the correct width will work. Just go cut one out from Lowes or Home Depot 2ft is plenty.
Old Apr 14, 2010 | 06:29 PM
twentyhurtz's Avatar
um.. make sure its radiator grade hose..
Old Apr 14, 2010 | 08:20 PM
i found this part number 79721-st7-000 i think this is the hose but im not sure.
i was also wondering if the water inlet is in a different place on the gsr head from the type r
Old Apr 14, 2010 | 10:07 PM
racebum's Avatar
did the same swap only in a dc2. had no issue, water temp sensor wires have to be extended. hose, i really can't remember. i either used my stock gsr one or used a length of goodyear hose from the parts store. any rubber hose will work so long as it's braided reinforced for the temperature and pressure. coolant hose is under $2/ft
Old Apr 14, 2010 | 10:13 PM
racebum's Avatar
actually, i'll be really helpful and get pics for you. okay, this is the stock hose off the valve out back BUT it's not necessary to buy a honda part at all for this. it's just a point A to point B hose with no trick bends. 3ft of hose will do you.
Old Apr 14, 2010 | 11:21 PM
ill just get the three feet of bulk hose. thanks for the pics
its just weird that its such a hassel to get that hose
thanks for the help
Old Apr 15, 2010 | 12:47 PM
mouab18c1's Avatar
thanks for the help
I highly doubt you will need 3ft but then again you could use it for something else.
Old Apr 15, 2010 | 02:18 PM
racebum's Avatar
it's somewhere closer to 2ft but a guy always buys long. especially when it's $1.50 a foot
h4x
Sep 11, 2012 05:08 PM
Frost_1097
Jun 5, 2007 10:21 AM
itellyawhat
Feb 18, 2005 12:00 PM
EARLdaSQUIRREL
Aug 5, 2003 05:36 PM
