Need help ASAP
ok my trailing arm on my 1998 dx is screwed i got in a wreck the thread is here https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/wrecked-my-civic-2755418/ and i need to some help on removing it i found all the bolts but i dont know how ot remove the brake line ? any help would be appriciated and pics or links would be much appriciated.
Just unbolt the ebrake cable from under the car and detach it from the inside under the console cover(for the ebrake) and you will need to unbolt the brake line(rubber) from the hardline. folow the rubber line and you will find a connection point where it will unbolt.
darthvaderglen
Suspension & Brakes
Jun 9, 2018 02:47 PM
all stock
Jun 28, 2003 04:19 PM
