** HYBRID RACING BOLT IN K SWAP SHIFTER **
5-27-10 We have three shifters left available from our incoming shipment. After these last three are sold they are going to be on backorder again for 2-3 months. If you want a Hybrid Racing Shifter, get your order in now before they are gone.
For many of those with K swaps and those considering a K, cutting out your shifter tunnel makes you nearly cry. Up until the release of the Hybrid Racing Bolt-in Shifter box the best solution was to install a Karcepts shifter mounting box. Well now those days are past. The Hybrid Racing Bolt in shifter box is THE best K series shifter available for Civic/ Integra's with K swaps. The shifter simply bolts in under the shifter tunnel and allows the shift lever to pass through the factory shifter hole into the cabin. The shifter cables are completely under the shift tunnel to eliminate the chance or air/exhaust gasses passing through holes and into the cabin. Among all these benefits, the Hybrid Racing Short shifter also comes with a ton of awesome features:
- Adjustable shift throw from 90% of stock throw down to 40% of stock throw.
-The front to back / left to right adjustment is independently adjustable to fine tune the shift pattern / shifter feel to EXACTLY how you want it.
- The adjustable shift **** height allows the EXACT height that you want your shifter at.
- The center portion of the shifter shaft has an adjustable offset to allow the upper portion of the shifter to be rotated 360 degrees to move the shift **** further or closer in several different increments to get the perfect shift **** location for hardcore racing or comfortable daily driving.
- Unlike the stock RSX shifter box, the Hybrid Racing Bolt In shifter has stainless steel pivot points for a much improved shifter feel and much longer life than the stock RSX K series shifter assembly.
- The aluminum shifter offset block fits either under OR over the shift boot for a clean installation.
Here are some photos, You will quickly see that this is the most advanced K series shifter on the market.
As of this posting, all of these Hybrid Racing shifters are on national backorder. We are expecting a large shipment near the end of May and are currently taking pre-orders for those who would like to get in on one of these from our next shipment. These are first come, first served. Placing your order will reserve a unit for you from our next order.
Pricing is set at $379.00. All units pre-ordered will be shipped FREE SHIPPING to the lower 48 States upon arrival. International shipping to MOST countries is $55.95. You can call us to order 209-324-9880, or order online 24/7 using coupon code FREESHIP here for a Hybrid Racing Bolt-in Shifter
Any questions, please don't hesitate to contact us via phone, email, or PM.
- HA Motorsports -
209-324-9880
email: sales @hamotorsports.com
Click here to for more info on the Hybrid Racing K Swap Bolt In Short Shifter
Just to let everyone know: If you already have your RSX shifter installed using a Karcepts shifter mounting kit, you can still use this Hybrid Racing Shifter. The front and rear mounting points are the same as the Karcepts mounting kit where it bolts in the shifter tunnel
Call us if you have ANY questions 209-324-9880
HA Motorsports
HA Motorsports
When calling to place your order you will need to pay in full for your shifter in order to reserve yours from the next shipment. There is only a limitted amount coming in and these will go fast! Call us 209-324-9880, or you can pre-order online http://www.hamotorsports.com/hrshift01.html
Is there any word on when the shipment after this one may be in? If I can come up with the money this is definitely how I would like to go, but won't have the funds until about the point where the order looks to be going through and don't know if there will be any left. This setup looks too sweet.
Told you we would, just had to rebuild the backend of the business and get everything ready to take over the world
You have been PM'd.
Yep, that's him!
Will be one of the best investments you ever make!
Yep, that's him!
